Kenmore White Electric Stove Logo
A
Anonymous Posted on Mar 08, 2016
Broiler element not working, replaced with a new one, but still not working. Bake element works fine? Broiler does not work. Broiler fuse ok. Element checks ok with an ohm meter. Boiler relay clicksOn
Broiler does not work. Broiler fuse ok. Element checks ok with an ohm meter. Boiler relay clicks on when broiler function is enabled. No error codes.
1 Related Answer
Anonymous
  • 2468 Answers
  • Posted on Apr 25, 2010
SOURCE: Left burner is not working
these elements merely unplug when you lift up the one side of the element,then just easily rock back and forth till it unplugs from the stove top
Dacor cooktop- won't heat
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter.( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advicebcuzGod is so good!
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges,the oven temperature sensor
is the part thatregulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meterbut will need to know the correctresistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check foroverheated wires or faulty terminals first.Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
  1. If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.(Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
  1. On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
  1. Set yourmultimeterto ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
  1. Repeat the step above for the terminals "L2" and "H2".
  1. If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
  1. With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
  1. A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
Most modern ovens usean electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter.If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve.This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
I have a smeg sai63 induction cooktop and we cant turn on any elements, there is power what could be the problem?
THINGS TO CHECK:
the broil element
The bake element
Surface burners
The infinite switch
Euro kera
THINGS TO CHECK:
the broil element
The bake element
Surface burners
The infinite switch
Bottom of oven does not heat properly
THINGS TO CHECK:
the broil element
The bake element
Surface burners
My frigidaire fef368gch was working fine and then the oven just stopped baking. It will broil but not bake. What causes this and how do I fix it?
Good Morning Shari,
I see that you are having trouble with your Frigidaire range, model# FEF368GCH, and the bake element not working while the broil element is. I suggest giving your appliance a hard reset, by shutting the power off at your home's circuit breaker, for 2-3 minutes. When power is restored, you will have to reset the clock by entering in the time and pressing start. Start a bake cycle, and if you notice that the bake element is still not working, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Top burners work,broiler works,oven does not
check and make sure the bake element has continuity.If there is not continuity with your ohm meter then replace the bake element.
If it tests good the replace the main Electronic control board or the oven switch which ever the unit is equipped with
Feb 23, 2010 • Cooktops
Bottom element is not heating
bottom element need to be replaced,unplug unit,and open the oven and unscrew the screws that hold it inplace,pull it out slowly and detach the two wires and replace with a new one install in reverce order
Feb 16, 2010 • Cooktops
Bake and broil do not work
assuming that the worst case senario has taken place
first thing i would check is ensure i have proper voltage at the outlet, 120 from each side to ground
220 across L1-L2
the elements are the only thing on the range that uses 220v
if you know how to use a mutimeter
you can test both the elements
disconnect the range at teh breaker
take out the screws at the back wall that hold the elements in
pull out about an inch becareful they dont leave much slack on the wires
disconnect on element terminal and apply your leads your looking for continuity, your meter should beep
if not replace the element
if yes, let the element hang ensureing niether terminal touches anything, reconnect the other terminal
now turn the stove on bake if your doing the lower
turn you meter to ac voltage
you should read 220v
anything less than that, your problem is before that
JENN AIR WALL OVEN ELECTRIC
Are you sure the breaker didn't trip on one side? If one leg of the 220 is out, the lights and controls will appear to work, but the elements will not heat up. Make sure you have 220 to the appliance. It's also possible that you pulled a wire off somehow when changing the broil element.
Sve47100 oven doesn't heat
Test the swtich w/ multi tester /connect tester as a jumper to the switch dettach one line on and off switch /if does not reponse / replace the switch.
Top Kenmore Cooktops Experts
Kolbrun...
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
