Most
gas ranges currently available employ one of 3 basic gas ignition
systems; pilot ignition, hot surface ignition system (which uses a
'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition
system. The latter two being referred to as "electronic ignition"
systems as they use electricity in one form or another to operate the
oven heating system.
Only the pilot ignition system has an actual "pilot" (which is a small but real "flame")
which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems
and thus will not usually have a "pilot" which needs lighting. Be aware
though that just because the surface burners might light via a spark
doesn't necessarily mean the oven uses the spark type ignition system
too.
There is one older style of electronic ignition system which
does
also use an oven pilot but it is very rare and such a system hasn't
been used in oven models since the early to mid 70's. It is the
'constant pilot' *electronic ignition* system
