Question about Razor A107. 24V Dirt Quad
Installed new 24v batteries and charged, but will not start. What else could be the problem?
Green ready light on Pride Sonic three wheel scooter wont turn on. What turns it on?
Hi if it is similar to pride x the circuit will shut down if key is left on for 20 minutes u will still have lights. Remove key for a short time then replace it & turn on ..goood luck
Jan 21, 2016 | Pride Sonic 3 Wheel Portable Scooter
New Nest thermostat, Model 2.8 Software version 4.0.1 keeps getting a low battery and shuts off and shuts down the furnace. Please help.
Do you have a common wire? The nest thermostat needs the common 24V C wire installed to keep the battery charged fully. Nest should tell consumers of this problem, but they don't. Its required for any powered thermostat. Even the new fancy Honeywells with touch screens etc..
Gotta realize the battery cannot run the display and wifi plus all the sensors for very long.
Jan 23, 2014 | Nest Learning Thermostat 2nd generation
E100 scooter wont run. Battery fully charged, 24v across terminals. Motor runs fine when connected directly to battery power. On-off power switch, breaker switch, brake unit switch, accelerator all checked...
It is possible the new controller is defective, however just because the voltage is showing 24v it may not be outputting the correct amount of amps so don not rule out batteries before checking the following:
To test a battery you need to 'load test' so (with help) connect the battery directly to the motor when weight is on the scooter to see if it will still pull.
Please also remember that you do have to push the e100 to 3mph before starting (many users do not know or forget this step)
Jul 04, 2011 | Razor E100 Electric Scooter
I fitted new batterys, now the joystick is reading low battery but no responce from the joystick.the batterys are wired red to red and black to black does the chair turn this to 24v itself, theres no...
Will you don't say what chair you have and they can all be wired differently. Look under the shroud that covers your batteries and see if there isn't a wiring diagram there. If you let me know the brand ie: Pride Jazzy, Invacare M51 etc. I can give you the proper wiring for the batteries. Now you also didn't say if you charged the batteries after you installed them. Remember always charge before use. Just because they are new doesn't mean they are charged (in fact they could have sat on the shelf for a while). Make sure that they are no older than 4 months old even new batteries can be bad. Charge these puppies overnite. When you plug in the charger you should see a red and yellow light after charging overnite you should see a red and green light( indicating full charge) If when you plug the charger in you get a red and green light then something isn't wired correctly. Hope this helps
Oct 27, 2010 | Health & Beauty
I have a Black Max 24V, model JD610424 and when I put the battery in the charger, nothing happens. I just cannot charge the battery. ****
Black Max 24v power drill
Allied International sells them at 1-800-248-6657, drill part # JDB240R. Have the part number from your drill available (on the label on side or top of drill...a number like 33643)
Mar 07, 2010 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
My new Black Max 24v drill charger will not charge the battery
You indicate that the drill is new. I'd suggest you return it for a replacement. Seems to be a defective or wrong charger. If you have problems and If you paid by credit card call the card company and have them stop payment on that charge.
Feb 21, 2010 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Razor A107. 24V Dirt Quad Logo
757 people viewed this question
Top Razor Rock & Ice Climbing Experts
ray gallant
ray gallant
Are you a Razor Rock and Ice Climbing Expert? Answer questions, earn points and help others
