Need an operating manual for the Maytag washer dryer about 20 years old - SE1000 series 06 serial number 111336
Jules, Check the attached links, for your manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Maytag Maytag Washer Dryer SE1000 Manuals Guides
Free Maytag Washer Dryer User Manuals ManualsOnline com
Maytag SE1000 repair manual online
My SE1000 Model Overview from PartSelect ca
Search the internet for:
Make + Model + the word "Manual"
SOURCE: Maytag haevy duty stack washer dryer unit model # SE1000 series 06
I hope you got this fixed by now but if not I'll put in my 2 cents.. I assume that your dryer is electric and not gas. Assuming that is true then you probably have an open heater element.. similar to this used in electric stoves... There may also be other components that could have failed and in so doing, disabled power to that element. Could be a contactor or temp switch/thermistor.. Hope this helps and that you've already solved the problem...
SOURCE: How do I hook up old washer Matag
Actually, your model is an A-612S ("S" is for Suds Saver). What do you need help with?
