Leaking fridge part of fridge freezer, cannot see any source for the water leak internally. Puddles under veg box and flows out
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
SOURCE: Kitchenaid Superba 42 Refrigerator Leak under Freezer when Water Used from Door
Either the water filter isn't seated properly or there is a crack in the tubing or the water line isn't seated properly in the coupling behind the grill at the freezer door. Also, inspect for breakage in the line in this area as well (coupling area).
SOURCE: internal water leak Amana AT5518SW
When water collects in bottom of frost -free fridge , first suspect is drain opening behind plate covering evaporator in top freezer. Drain opening is into vertical tube running down to bottom of fridge and into collection pan under the fridge where the water is allowed to evaporate into room air. Reaching the drain opening directly is not always easy and blockage in my case was bits of matter. I was able to force water with a hose and fittings up this drain tube exposed with back cover off and had gunky-like material pour out of fridge. It was the solution.
SOURCE: Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
SOURCE: water inside refrigerator
Even though it doesn't seem like it's coming from your freezer, morre than likely that's where it's coming from. At the back of the fridge there will be a drip tray that actually catches the water from the thawing freeze. One way to avoid access water is to simply turn down your freezer and fridge. Usually if they are number 0-10, both frigde and freezer should be set on the 5 level.
