Radio Communications Logo
R
Richard Akam Posted on Mar 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi anyone have the manual for JOHN LEWIS World Traveller Band RADIO. I want to save 5 stations. There is a memory button and 1-5 station buttons. It must be so simple! Thanks rbakam
Manual would be great.
Clint Millett
Level 2:
Novelist:
  • Expert 217 Answers
  • Posted on Oct 02, 2016
Clint Millett
Expert
Level 2:
Novelist:
Answers
217
Questions
0
Helped
87210
Points
355
Usually you just set the frequency and then press and hold the memory button for a few seconds.
3 Related Answers
A
Anonymous
  • Posted on Oct 28, 2008
SOURCE: uniden washington base station
I need the wireing information for uniden washington CB radio,thank you.
Anonymous
  • Posted on Mar 14, 2009
SOURCE: does not transmit. it has receive and weather
The PLL chip is burned out
Anonymous
  • Posted on Aug 19, 2012
SOURCE: I need a manual to base station CB Ranger RCI-2990
you can download a free manual on cb tricks
How to set channels for stations so they are locked to my stations
You can let the Yamaha HTR-5660 set stations for the FM band automatically. To manually set the station in one of the memory banks, first tune to the desired frequency (AM/FM band). Press Memory on the receiver. The memory light will flash for 5 seconds. Press the A/B/C/D/E to select the desired memory group while memory light is flashing. Make sure that you see the colon after the letter. Use the preset/tuning left right arrows to select the memory bank (1-8) to use in that group. This also needs to be done while the memory indicator is flashing. Press Memory to save the frequency in the desired memory location. If that memory group and bank had a station frequency stored in the location, it will be erased and the new one saved. If you do not finish the procedure before the Memory indicator stops flashing, you will have to repeat the steps.
You can recall the stored stations from either the remote or the receiver by pressing the A/B/C/D/E button multiple times (as needed) and the preset/tuning buttons. On the receiver, the A/B/C/D/E button is also the Next button. On the remote, it's the Menu/Set Menu button.
The steps for presetting stations is shown starting on page 33 of the manual, https://www.manualslib.com/manual/197490/Yamaha-Htr-5660.html?page=37#manual . The entire manual is available here: https://usa.yamaha.com/files/download/other_assets/3/319793/01_om_htr-5660.pdf .
I hope this helps.
How to program the radio in a 96Lincoln continental after battery was disconnected
Here is the link to the owners manual which you can download if you wish:
http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=1996&make=Lincoln&model=Continental
Here/below are the specific instructions on the radio programming (pg. 159 of above link).
Good luck & please flag if "HELPFUL". Thanks!
(from section) Luxury Audio System
Selecting the AM or FM frequency band
Push the "AM" or "FM1/FM2" button to select the desired frequency band. Pushing the "FM1/FM2" button more than once will alternate between FM1 and FM2. These functions are used with the station memory buttons described under How to tune radio stations.
HOW to tune radio stations
There are four ways for you to tune in a particular station. You can use the "TUNE", "SEEK", 'SCAN"or memory buttons.
• Using the "TUNE" function:
You can change the frequency up or down one increment at a time by Pressing and releasing either the left (< arrow/up) or - right (> arrow/down) side of the "TUNE" or "TUNE DISCS" button. To change frequencies quickly, press and hold down either the right or left side of the button.
Manual tuning adjusts your radio to any allowable broadcast frequency, whether or not a station is present on that frequency. (See All About Radio Frequencies in this section.)
• Using the "SEEK" function
: Press the right *) side of the "SEEK" button to select the next listenable station up the frequency band. Press the left (.4) side of the button to select the next listenable station down the frequency band. By holding the button down, listenable stations can be passed over to reach the desired station. Pressing the "SCAN" button will begin the scan mode up the frequency band, stopping on each listenable station for approximately five seconds. To stop the scan mode on the presently sampled station, press the "SCAN" button again.
Setting the station MEMORY PRESET buttons
: Your radio is equipped with 6 station memory buttons. These buttons can be used to select up to 6 preset AM stations and 12 FM stations (6 in FMI and 6 in FM2)
1. Select a band, then select a frequency.
2. Press one of the memory buttons and hold until the sound returns and the lamp above the memory button lights up. That
memory button is now set.
3. Follow the above steps for each memory preset button.
NOTE:
Custom memory presets can be recalled using the keyless entry system. See Memory Profile System in the Features chapter.
Using the Automatic Memory Store feature ("AUTOSET")
: If the memory buttons have been set, either by using the Auto Memory Load feature or if you have set them manually, the system is prepared tolet you use a convenient feature called Automatic Memory Store.
With Auto Memory Store, you can continually set strong stations into your memory buttons without losing your originally set stations. Your radio will automatically set your memory buttons to the strong local stations.
Activate Auto Memory Store by pushing the "AUTOSET" button once. Your radio will set the first six strong stations of the band you are in (AM, FMI or FM2) into the memory buttons. The display will flash "AUTO" and display the autoset icon "A" while the stations are being set in the memory buttons.
NOTE: If there are less than six strong stations in the frequency band, the remaining unfilled buttons will store the last strong station detected on the band. After all stations have been filled, the radio will begin playing the station stored on memory button 1.
To deactivate the Auto Memory Store mode and return to the manually-set memory button stations, simply push the "AUTOSET" button. Display will show "AUTO" then "OFF". The next time Auto Memory Store is activated on that band, the radio will store the next set of six strong stations.
Just picked up a Technics ST-S76 am/fm tuner complete with cords but no operating manual - of course. How do I program in radio stations to memory? or Find an operators manual?
To program your radio stations to the memory buttons; Tune to the station that you want to save, then press the memory button (located next to the FM mode button on the lower right side of Tuner) then press the number button that you want associated with that station. You may save up to 24 stations. If you want to save a station in memory 10, tune in station, press the Memory button, then press 1 followed by 0. you must press them within a couple seconds of each other, or the first number pressed will be the memory button that saves. You may save FM stations and then Save AM stations. But you will overwrite any previous station saved to a given number when using that number again. If you save an FM station on a number, then save an AM station on another number, when you press the preset number, the tuner will automatically switch radio bands to accommodate the stations given band. cool.
How do you set stations and clock
1.Select the radio band and tune in a desired radio station you wish to store in the preset memory.
2 .Press and hold any one of the Preset buttons (1 through 6) for at least 2 seconds until the station frequency on the display blinks.
3. Press the Preset button into which you wish to store the station while the frequency display is blinking (within 5 seconds). The display stops blinking once the station has been memorized. The display shows the band, preset No. with a triangle (9) and station frequency memorized
http://vault.alpine-usa.com/products/documents/OM_CDM-7854.PDF is link to full manual
1helpful
I knave a teac model ex cd3. Have lost the manual. Can't remember how to reset the radio stations. Can you help?
OK press power on,select tuner button for radio. then select band AM or FM. Then press tuning mode button until you see [manual] in the window. then press the tuning button [arrow left or arrow right buttons] until you get to your desired station.then press program / memory set. a memory number will flash [ say memory 1]. then press program/ memory /set button again to lock in the selection [memory 1] now this is the TRICKY PART. Once the selection is memorized go back to tuning mode Press the tuning mode button until you see manual and i think you can follow the above procedure. If you program AM stations first Then press the BAND button to get FM stations and go back to step one.
1helpful
Brookstone SLCDv2.0 The device clearly has a Memory capability since there is a "Set" button and the display shows "Memory" when the button is pressed at a particular FM station. ...
Hi, The receiver does have an in built memory to store upto 6 channels.Please follow the steps below to set up the radio memory:- Up to six favorite radio stations (3 AM and 3 FM) may be stored in memory. the following are steps to set radio memory: 1. Press tUnInG/bAnD to select the band. 2. turn tUnInG/bAnD to locate the desired station. 3. Press the M button. the "M" indicator flashes on the LCD Display. 4. Press 1, 2 or 3 to store the selected station. 5. Press the M button again to confirm. 6. repeat steps 1-5 to set other memory stations.
Incase you would require any information do refer the below web site where you could find picture representation of the same. http://www.brookstone.com/linkedassetservlet?assetId=71937&languageId=EN
Thank you for your time and best wishes for your effort.
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
1helpful
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
4helpful
I can't preset radio stations
this is how i preset my stations, im not sure if you have done this before.
fm can save 20 stations and am can save 12
1] chose your desired station
2] press & hold the play/memory button until P01 pops up and flashes
3] to save the station, press & hold the play/memory button
if you'd like to save another station, then repeat steps 1 & 2,
then press the play/memory button again until P02 pops up,
repeat step 3.
to listen to your preset station, all you have to do is press the play/memory button.
hope this helps
2helpful
Program stations
Quoting from page 6 of the manual:
"Select the radio band and tune in a desired radio station you wish to store in the preset memory.
Press and hold, for at least 2 seconds, any one of the preset buttons (1 through 6) that you want to store the station on. The selected station is stored. The display shows the band, preset number and station frequency memorized. A total of 18 stations can be stored in the preset memory (6 stations for each band; FM1, FM2 and AM). If you store a station in a preset memory which already has a station, the current station will be cleared and replaced with the new station."
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=934dc6a1672f80b9d320c470df81f04d&q=Alpine+CDE-9842
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
