Pride Pursuit - 4 Wheel Scooter Logo
w
whitford tim Posted on Mar 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flash code 8 motor voltage error means - Pride Pursuit - 4 Wheel Scooter
Jeff Bird
Level 3:
  • Pride Master 1,348 Answers
  • Posted on Mar 07, 2016
Jeff Bird
Pride Master
Level 3:
Answers
1348
Questions
0
Helped
363077
Points
4615
Hi get in touch with pride www.pridemobility.com.au ...good luck
I have a ezgo p3211 power wheelchair just put new batteries in it and lights are flashing and it won't drive.
The lights flash in a systematic sequence which reveals an VSI error code. Count the number of flashes.
1. Battery needs charging
2. Left motor bad connection
3. Left motor shorted
4. Right motor bad connection
5. Right motor shorted
6. Unplug battery charger
7. Joystick fault. Make certain the joystick is in the neutral position (centered) before turning on the controller
8. Controller fault. Check connections
9. Parking brakes bad connection. Check connections to parking brake, motor and controller
10. Excessive voltage. Check battery charger connections.
1helpful
I have a problem with invacare meteor scooter ,it randomly wont go forwards,most consistant thing i noticed is it jerks to a stop,after that it wont go forward and flashes 8 code/motor fault
Hi AGAIN HAVE TESTED the SPEED CONTROL potentimeter & WIG WAG FOR THERE CORRECT RESISTANCE IN OHM'S .ANOTHER POSSIBILITY IS THE LITTLE COMPUTER ( CONTROL BOX )IS FAULTY good luck get you're batteries LOAD TESTED..ERROR CODE 8 IS ALSO A MOTOR VOLTAGE ERROR cheers
img_20180518_192320-2n4i1ve51ezgzxt22yhmjm2x-2-0.jpgimg_20180518_192502-2n4i1ve51ezgzxt22yhmjm2x-2-2.jpgimg_20180518_192502-2n4i1ve51ezgzxt22yhmjm2x-2-3.jpg
1helpful
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Trotter by cybex model 900t code 8 error
Error 8, is a power fault error. This means the drive motor voltage dropped below 190 VDC for 5 seconds. This could be caused by worn motor brushes or the lower control board.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
1helpful
8 flashes will not move
8 flash code on this scooter relates to a motor voltage fault. This means that the correct voltage is not getting to the motor from the power supply. This can either be caused by a bad harness between the power module and the motor or a problem with the motor itself. You need to measure resistance between the motor harness and intermediate motor harness this will determine which component needs to be replaced.
4helpful
2 error codes on 2008 nissan sentra p2101 and p2118 what do these codes mean? only has 24,000 miles on the car
code P2101 (which is a Throttle Actuator Control Motor)
Trouble Code: P2118
Electronic Throttle Control Motor Circuit Malfunction
Trouble Code Conditions:Ignition is on and ETC motor is not in limp-home mode. When the PCM detects an internal error or short between the ETC motor and ETC motor positive circuits in the ETC motor driver. The ETC light will be flashing.
Possible Causes:
  • Throttle plate or bore malfunctions
  • ETC positive circuit is open or is shorted to ground, battery voltage or ETC negative circuit
  • ETC negative circuit is open or is shorted to ground or to battery voltage
  • ETC motor has malfunctioned
  • PCM has failed
2helpful
Screen turns green and small red light on front flashes 8 times
to me this is pointing towrd a bad (possibly shorted)green crt tube. howerver other possiblilities could be bad hig voltage distribution block(g2) 8 flashing means high voltage error. or an error on the d cuircit board error
14helpful
4answers
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
11helpful
3answers
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
