Hi Anonymous, we want to help you with your question, but we need more information from you. Can you please add details in the comment box? being a Jabra device did you put the Jabra Eclipse into pairing mode ?Hi Anonymous, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
most pairing when asked by the device requires a 00000 passcode but you need to set the jabra and the iphone up for pairing here is a link for jabra the iphone should see it when the jabra is set to set up mode.. http://www.jabra.com/support/Jabra-JOURNEY_100-47300000-15
I just had this same problem. I solved it by turning the iPhone Bluetooth off and then back on, after which the pairing (with passcode 0000) worked properly and so does the headset.
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time
you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
1. Put the headset in pairing mode • Make sure the headset is off . • Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
You might want to delete the Jabra headset from the Rumor first, and make sure the phone is powered off. Then put the Jabra into pairing mode (usually done by powering on the Jabra and pressing and holding until the indicator light flashes) and set the Rumor 2 to detect new devices. Once it detects the Jabra, connect and input 0000 (four zeros) and it should connect.
No problem. When Jabra is off, press and hold till green light turns blue. On the iPhone: settings, general, bluetooth; switch to on. It will search, then it will list the Jabra BT8040, not paired. Highlight the "not paired" line, and it will start to pair; a few seconds later, it will say "connected".
You have to pair the two devices first.
Use your phone to detect other bluetooth devices, when it finds the model Jabra you are using select it. Reset it before you start.
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 modeMake sure that the headset is on.Press the answer/end button andpress the volume up (+) button at the same time,until a solid blue light comes on.2. Set your Bluetooth phone to ediscoverf the Jabra BT150Follow your phonefs instruction guide. This usually involves going to a esetup,feconnectf or eBluetoothf menu on your phone and selecting the option to ediscoverfor eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4)3. Your phone will find the Jabra BT150Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf onthe phone and confirm with the passkey or PIN3 = 0000 (4 zeros).Your phone will confirm when pairing is complete. In case of unsuccessful pairing
