When I went into device manager I and clicked on the printer I was able to print a test page. Eveything else in the que does not print.
SOURCE: unable to clear printer queue
I had a related problem. Couldn't delete a job from the queue nohow. I wound up deleting various processes (CTRL ALT DEL PROCESSES tab) and it cleared it.
SOURCE: Trendnet TE100-P1U won't print
open the print server utility and the doc can be cancelled or deleted from there. (this is the server utility inthe toolbar at the bottom of a windows screen. failing this go to the printer shortcut and from control panel>printers> select printer and faxes>select the printer (open) >select "printer" from menu bar, pause printing,then cancel all documents. Afterthis you can delete printers that are excessivly created, or delete all of them and start again with only the one or two printers you need. even if one is for network use and the ther is direct connect. You canuse direct connect to verify proper printer operation until te100 is working properly
SOURCE: Printer not printing documents in que
I have a Dell Photo 926 all in one fax, My print Docs are going in Que. What is the problem with the printer?
SOURCE: HP 2840 printer pause will not resume
uninstall your printer and then re-install it that should fix your issue,it could be a bad version of an updated driver that is causing the problem
SOURCE: deleted print job stuck in queue
You can always restart the computer, that will "unstick" a print job that gets stuck deleting.
Go
to device manager(right click my computer, left click properties,
left click hardware, left click device manager)
Go to the USB Controller section and click the + sign.
Go to each USB Root Hub and right click on it, left
click properties, left click power management. Uncheck the box, allow
computer to turn off this device to save power.
Restart your computer.
Rick
