If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
SOURCE: vision 42 inches plasma tv
It sounds like there is a problem with the tuner inside the television. Your best bet is to send it in for service.
SOURCE: half of my screen has an image and other half is black
I have this fault listed in our database on this exact model, we put it down to an LCD screen fault, the TV was returned unrepaired.
New screen's are too expensive.
Sorry I'm the harbinger of doom.
I hope this helps.
SOURCE: Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
SOURCE: Sony Bravia LCD black shadow screen
You may ahev failing T-CON board, try having a small fan blowing at the vent on the back of the TV. If you can post pictures it will help a lot.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
