Have a jacuzzi jet tub,3/4 hp vantage pump with air switch.fill tub,turn it on.pump comes on and pushes water out of jets for few seconds and then shuts off.Also pump is very loud
SOURCE: Bathtub jacuzzi (motor turns runs but nothing coming from jets)
Each Jet will have an adjustment many times right on the jet nozzle. Carefully try to rotate them counter clockwise to open up the jet. This assumes you can here the motor running.
Phil
SOURCE: Only 3 of 6 jets in jacuzzi tub working
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
SOURCE: Jacuzzi jets not pumping out water
Check the jet pump, also where the filter is there are two 90s plastic. make sure that they are both in the water, if all those check out then check the switch for the jets. It sounds like the pump is bad and is not pumping the water. Even if the motor works and the internal parts of the motor seal gets wet then it all needs to be replaced and rebuilt. Very easy to do yourself. Like always be careful and unplug the unit.
SOURCE: jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
SOURCE: I have a Jacuzzi Espree 6036 and switch will not shut off whirlp
Hello. yes you can replace the switch. All of the parts come with instructions. plus you can call the jacuzzi repair technician directly and have him/her talk you through the procedure at 866-905-2289. here is the owner manual in case you don't have one
http://www.guillens.com/jacuzzi/images/ESPREE.PDF
