If I take the filter out the filter it runs fine. But when I put the filter in it starts and stops like I'm releasing the trigger. Please help....it's only 2 months old.
You can wash the filters in cold water until it runs clear (without using any detergent or soap). While you should squeeze and twist the long pre-filters to dislodge any dirt inside, you can simply rinse out the post-filter, taking care not to damage the pleats inside
My facebook: ? https://www.facebook.com/hannah.jparrish.3 ?
Hi there, it's Jack at Dyson.
Your Dyson V6 vacuum is designed to make a pulsing noise to warn you when something is preventing airflow from passing through the machine. This could be a blockage in the motorised floor tool, wand or bin inlet. It's also a good idea to check the bin inlet flap can open and close freely, and isn't jammed in place.
Our video support guide will walk you through the simple troubleshooting checks:
I'm confident that removing any blockages and checking the bin inlet flap will resolve the issue with your machine. But if you would like any further help, just give the Dyson Customer Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
The filters do need to be cleaned, normally washed and then air dried
