Question about KLH R3100 Remote Control Unit Only
How do I turn it off
Won't switch off and on
Scoot runs and drives fine but will not turn off by ignition
Hi, Zak you may have a faulty ignition switch for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day. Scooter won turn off
how to fix gy6 Scooter wont turn off kill switch not working Great Prank...
GY6 Scooter wont turn off kill switch not working Great Prank Keeps...
http://www.apriliaforum.com/forums/showthread.php?227549-2001-SR50-Won-t-shut-off
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 02, 2016 | Motorcycles
Why won`t the fan of my venmar range hood turn off?
Sounds like you may need to replace the fan switch. The fact that it wont turn off and that it only works on low speed supports that switch is broken.
Apr 24, 2014 | Venmar Kitchen Ranges
My 98 carrolla ignition switch won't turn I got it
Hi Anthony,could be your neutral safety switch,here's a link on how to replace and here's the part.And if I am wrong at the neutral safety switch and it is the ignition switch is bad,here's how to replace.Here's the part.
Mar 24, 2013 | Cars & Trucks
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
96 celica won't turn over
If the engine won't crank, it could be the starter, battery, connections, neutral safety switch, or key switch.
Jul 03, 2012 | 1996 Toyota Celica
2002 saturn sl won't start, turn over but won't start
Done cars have a kill switch if they are low on oil. Check your oil. If the oil is good, it may be the ignition switch.
Jan 01, 2018 | 2002 Saturn Sl
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
When I turn on the vehicle the headlights and windshield wipers come on and won't turn off. When I turn the key off there is a delay before it actually turns off and the headlights won't turn off.
This sounds like an issue with your ignition switch. Basically what is happening here is that you are shutting off your vehicle, but the ignition switch is not working correctly and is allowing certain accessories to stay on.
Jun 17, 2011 | 1992 Dodge Caravan
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
KLH R3100 Remote Control Unit Only Logo
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
