reset it somewhere to push a few buttons together by reboot or start this will maybe the tablet goes booting in a bios factory mode with Chinese symbols like a Polaroid smartphone.
Most likely it is dead. If you tried a real factory reset, then just look for another tablet. Toshiba is not going to help you as, from my experience, they do not care after they sell you the prodcut and it gets out of warranty.
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
How to Reset Kindle - courtesy Andrei Pushkin
Kindle DX, Kindle 2 or Kindle 3: This is easy - just hold the power button (next to the headphone jack) for 15 seconds and the device will reboot.
Reset Kindle 1: This is trickier as you'll first have to remove the back cover; you'll also need a paperclip.
To reset/reboot your Kindle Fire:
-With the Fire charged but unplugged from the charger, press and hold the power button for a full 20 seconds.
-When the Fire cycles off completely, press the power button once to turn it back on.
1. Press the power button to get the option menu for
Power / Reboot / Silence option.
2. From that menu you'll have to hold down the Power button while holding down the Home button on the side of your tablet.
3. This brings up a menu to "Reboot Into Safe Mode" (These first 3 steps the manufacture fails to mention, which is where many users get stuck)
4. Hit yes for Safe Mode and then hold down both Power and Home buttons on side till the Dopo logo appears.
5. Release the buttons and hit the Power button one more time, then hold the Home button down till a menu option appears.
6. Use the Home button to move down to "Factory Reset" and press the Power button to select that option. Once it says "complete" then use the Power button to select "Reboot."
I got a Craig 741e (CMP741e), FCC ID AQF-RA-WN11087A with a lost password, stuck on a lock screen, forgotten pattern, no wifi connectivity.
The Craig does NOT support a reset mode, none of the typical combinations of power/volume buttons get you to a restore screen.
The only supported way to restore to default is a firmware restore mode.http://www.craigelectronics.com/site/pdetails.php?id=414 will tell you how to get the firmware file
The name of the core image in that RAR file is sun4i_crane_aihua_20121121, if that gives anyone clues about the system.
Installs the same way - will reboot several times after the firmware install completes, and will fail the first time it runs ("Unfortunately, <process name> has stopped." over and over again). One more reboot will solve that issue. The Flashing software, PhoenixCard 3.06, is VERY buggy. If would not work with my built multi-card reader on my PC or with an add on-SD card reader on that PC. (could not even see the card). On my laptop, the built in PCI Card reader never recognized the card, but it finally burned the card using the add on card reader. Some people suggest disconnecting ALL USB peripherals before burning. Also, I found if the flash burning failed over and over, sometime a reboot caused PhoenixCard to start working again.
