Broke the cable or broke the latch? If it's just the cable, sometimes you can sneak a long needle nose pliers in and pull the cable by hand. Otherwise, the only way to get in is to remove the grille, and that may damage it. Sorry. no other way
OK, if the cable is the part that broke AND it broke at the handle, then you can use a pliers or vise grip to grab the end and pull on it to pop the hood, if it broke somewhere inside the cable, then you will need some needle nosed pliers to reach under the hood and grab it there. if it broke off at the hood latch itself, then you will need to get/ make a hook or pushing rod to engage the mechanism directly to release the latch and then replace the cable
If What type of car? If e39 1997-2003 or 3 series 94-99, easy. buy small inspection mirror. look up by the latch. you'll see where the end cable connects. With a small stubby, move the plastic that the end cable attaches to, you are then moving the latch. Lift up hood. Of course you must pop out the kidney grill to gain access to the drivers side latch, 6 tabs hold it in. Hardest part of whole job is removing kidney grill. moving latch takes about 7 seconds.
Saturn Vue hood release can be opened (if the cable is not broken) by disconnecting the cable from the back of the release lever, grabbing the ball on the end of the cable with some large pliers ("channel locks") and pulling hard. A metal "wire keeper" bracket clamped to the cable end under the hood to serve as a spacer and the release lever works. The purpose of this bulletin is to provide a procedure for opening the hood on the Saturn VUE and ION vehicles should the hood latch release cable mechanism become inoperative. VUE Hood Opening ProcedureModify the Saturn radio antenna by bending the antenna mast 1 in. (2.54 cm) above the antenna base to a 25 degree angle Open hood of similar vehicle to locate hood latch release cable to hood latch attachment point. Using modified antenna, note approximate location that antenna will have to enter in between fascia and hood to access the hood latch cable attachment point. This should be toward the left edge of the Saturn emblem. Also note position of the modified antenna base. It should be angled downward. Note: Use protective tape on the hood and fascia where the antenna will be inserted to protect the surfaces from scratches On vehicle with inoperative latch, insert antenna between hood and fascia and depress the hood latch cable until the hood is opened.
my Malibu has a very hard to pull latch also. only way is to crawl under front of car and follow the cable to where it ends and manually push or pull the latch and hood will pop.
cable is a little worn,but what you can do is open the hood.on each side or the core support,its the long piece that is above the radiator are 2 black rubber hood stops,you can try bringing them up a little at a time(3/4-1 turn)equally as this will put more pressure on the hood and should pop right open.It may take mor ore less than the turns I said,also lube the hood latch with some good lube not WD-40 hope it works have a good day DB
You will need 2 people to get the hood open. While you pull on the hood release cable have an assistant gently pound on the center of the hood until it pops up. If this does not work, inspect the hood release lever to see if the pivot broken, if so pull directly on the cable with a pair of locking pliers. After you get the hood open make sure to spray the latch with penetrating oil (WD40)
