Drills Logo
m
mark hodges Posted on Mar 05, 2016
HOW DO I DISSASEMBLE THE MAKITA GSE 2200 - Makita Drills
1 Related Answer
xboa721
  • 37 Answers
  • Posted on Mar 05, 2016
SOURCE: My Makita gse 2200 had cut out and i dont know why ?
Sat idle for a few years? The start capacitor on the motor is probably dead. Replacing the start/run capacitor, typically 1.5uF to 2.5uF is easy if you can disassemble the unit. Any appliance spare parts shop has these.
The carbon brushes on a machine like this also may have failed (chipped and cracked) if you haven't run the machine for a long time and it previously did a LOT of work. The brushes are usually available as spare parts and easily changed.
1helpful
1helpful
GSE. Where is the fuel filter located?
Should be in the fuel line under the car or between the engine and firewall.
Keeps blowing internal breaker
The unit rated at 3 HP at 115 volts draws 13.8 amps is odd, a HP in watts is 745 and should be about 2200 watts and 19 amps plus a efficiency loss. Odd to see the ratings don't jive with electric theory/formulas.
The compressor should be connected directly to the wall and if using an extension cord, the cord needs to be #12 AWG or larger to avoid line voltage loss and over amping of the motor.
Here is contact and support info: For more information, please call 800/4-MAKITA (800/462-5482) or visit makitatools.com.
My bottom line is, A 115V motor circuit needs 10 amperes per horse power or 30 amp circuit for 3 horse power. Using extension cords calls for upgrade in wire gage of the cord. The advantage of using 230 volts is it cuts the amperes in half and allows use of smaller gage wire. Watts, or volt amperes is the product of volts and amps.
Opel kadette 1600 se torque settings
Conrod torque settings for opel cadett 1.6 gse
How to remove ignition from 1993 suzuki gse 500
you are going to have to remove the tripple tree. I am pretty sure the ignition is riveted into the tripple tree.
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
