Janome 11000 Memory Craft Special Edition Sewing Machine Multicolor - 00111000S JAN011-1 Logo
Terry Nocchi Posted on Mar 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Janome 11000 skipped stitches if any are even made at all
Won't make stitches when embroidering only when doing regular sewing.
R.A. Ellis
Level 3:
  • Janome Master 12,731 Answers
  • Posted on Mar 07, 2016
R.A. Ellis
Janome Master
Level 3:
Answers
12731
Questions
Helped
2615782
Points
59176
Skipped stitches sometimes occur if the machine is incorrectly threaded. Remove the thread and re-thread from the beginning (first RAISE the presser foot so the thread will seat in the tension disk).
Confirm that the thread follows the correct pathway (consult manual).
Try installing a brand-new needle.
Make sure the needle, thread, and fabric are compatible.
All About Needles
If it continues to not pull up the bobbin thread, the needle/hook could be out of time. May require service.
Sewing machine won pick up bobbin thread hook timing fix
1helpful
How can I get my janome 11000 to work when embroidering? The bottom thread doesn't even show and top thread is always breaking.
The tension(s) may be too tight and could be threaded incorrectly. Start out with a brand new needle. Be sure to RAISE the presser foot when threading the upper thread. Consult the owner's manual to be sure it is threaded in the proper order. Test your stitch on a straight stitch and adjust it so both threads meet in the middle of the fabric. This setting works for straight stitch. However, usually the upper thread tension is loosened a bit for embroidery so the bottom thread will not show on the top of the fabric. Test it on some small embroidery patterns first until it's where you want it.
Janome 1600P skipped stitches
Normal top tension is 3-4; normal bobbin tension (iirc) is 35 grams.
I'm betting, though, that a new needle, right way around and the correct size, would solve your skipping problems.
I have a janome 11000. it jammed while embroidering a project. The underneath was rats nest and my needle bent and gouged up my bobbin case...Replaced the case and now the machine makes a clicking noise...
sometimes when a needle gets bent, it can cause the sewing machine to need a adjustment by a technican.
sometimes a jam can be caused by the thread coming off the thread take up lever
or the bobbin is turned the wrong way in the bobbin case
or the bobbin was not thread correctly
Janome mystyle 28 won't stitch stretch material
Try a ball point needle which is for stretch fabrics. Using the wrong needle can cause skipped stitches.
MC4400 skips on the zig zag stitch when sewing
You must buse an anti static needle otherwise yoiu will miss stitches.
1helpful
2answers
Skipping stitches
Rule of thumb: Fast needle, slow hands. This should help. GiGi
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
