I would like the remove the ssid entry then try to reconnect, but can't figure out how to do this. Tried the usual router reboots & factory reset; reboots of nexus, etc. Is A factory reset of nexus next?? This all worked fine prior to And ver 6.0.1
Reads like you've got a faulty wifi module on the Nexus. Have you got warranty?
Thanks for your response. What I found after experimenting with the routers security settings is that the Nexus didn't like the specific WPA-PSK "TKIP" protocol. When I changed this to WPA-PSK "AES", Nexus authenticated immediately. The Nexus has been quite reliable. The android OS doesn't let you peek under the covers to try to chase issues. All help is 'on-line' which is UA if you can't connect.. Again, Thanks. Jim
Please disregard. Nexus didn't like the routers WPS-PSA 'TKIP', it works on the WPA-PSA 'AES' protocol
