I tried to get it to pair,but my phone didn't seem to recognize it, just asking
SOURCE: Wireless headset pairing
With the Samsung WEP210 this is a common problem (which is actually just a user error)
This is what you do:
1. Of coarse make sure the headset is charged
2. Make sure the bluetooth headset if OFF
3. PRESS and HOLD the top/middle (on/off) button until the light stays on (it will blink then should stay on continuously). That means it is now in pairing mode.
4. Tell you phone to search for bluetooth devices.
5. It should find the headset, and by default type "0000" to pair your new headset**
**You can use whatever pin code you like......but I would recommend the default which is four zeros.
SOURCE: Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
SOURCE: samsung 200 bluetooth
I had the same problem. To fix this, you need to keep hold of the button when you are turning it on until the light stays on - this is pairing mode. When the light is on, search for it on your phone and pair them up.
SOURCE: EM227 ASKS FOR PASS CODE ..I DONT HAVE WHY?
The pass code should be 0000 but if you get it synced. It will not stay connected. Its not your htc phone. I went to HTC's website to get the bluetooth update, installed it, and im still having the same problems. Its the piece of s#*% em227 bluetooth that is the problem. Your best solution is to go and buy a new bluetooth cause yours, just like mines, wont work. Have A Nice Day
