same problem here as well. I'm going to try and replace the ignition cylinder. Does yours start? Mine starts, but can't get out of park unless I move key to run (put in neutral) and start again, Issue dash is going crazy and running light are flickering. I noticed yesterday that the turn signal lever is hot, so it might be some short in the steering column
Best place to start is the positive lead on the battery . Remove the lead and clean battery pole and terminal using sand paper until you have shiny syrfaces. Replace the lead and tighten the terminal . Check the battery for charge condition as what you describe indicates a flat battery
First. I would look for a loose connector plug going to one of the fuseboxes, there could be corrosion in the connector even, Under the hood or under the steering wheel. 2nd. I would try to locate the ECM, could also be a bad connector there as well.
Make sure the connections and the cables are good.No corrosion on cables.If the lights in the dash flicker this is usually a sign that the battery is not good or it is not making good contact.Have the charging system and battery load tested.Hope this helps.Good luck.
