Power Acoustik LT-980/2 Car Audio Amplifier Logo
Posted on Nov 18, 2007
WIRING (MY PRODUCT IS NOT LISTED ON THOSE CATAGORIES.....MINE IS A POWER ACOUSTIK PTID-8960)I HAVE AN POWER ACOUSTIK IN DASH MOTORIZED 7IN. TOUCH SCREEN MONITOR, AM/FM, TV TUNER, DVD, USB, MP4 AND I POD....ALL IN ONE. I NOTICED ON ALL MY WIRING THAT THERE ARE WIRES FOR GPS.....CAN YOU TELL ME IF I WOULD NEED TO BUY EXTRA PARTS FOR THIS OR IF IT HOOKS UP TO SOME STORE BOUGHT GPS DEVISES? AM I MAKING ANY SENSE?
Jeremiah Bohn
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Nov 22, 2007
Jeremiah Bohn
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
8608
Points
25
You need to order extra components in order to use the optional GPS function.. you can try checking circuit city or the Authorized Acoustik Suppliers for the products like the websites or you can check Ebay as someone might have the product
Installing a ptid-8960 power acoustik into my new 2011 mazda 3 what wires should connect or can i even install it without getting the wire harness adapter to make it like the same connections not quite...
You absolutely should use a wire harness for this installation. Not using one would require you to clip the wires to factory radio connector, making re-installation of the factory stereo nearly impossible. Even worse, you would have to wire the connector that came with your PTID-8960 deck to the clipped ends. This task would be nearly impossible, as the factory wiring is too short to extend out of the dashboard where you can work with it easily.
Save yourself the trouble.
I tried finding the exact item you will need, but it seems the Mazda 3 comes with stereo options that could affect which wire harness you'd require.
Here is a link to Crutchfield: http://www.crutchfield.com/p_120707904/Mazda-Receiver-Wire-Harness.html?tp=2977&tab=other_items
You can use their site to select your car and installed options, and they will return products compatible with your vehicle.
My power acoustik 8960 touch screen does not respond
return it...it will start jamming when loading a disc and the fan will start to grind soon.  it is a bad unit..like all 3 I have HAD!!!!!
Speakers are thumping and cracking when powered up...why?
you are better off setting your deck speakers amp to a high pass filter setting on the amp. Adjust gains to increase desired bass and clarity. Turn off loud button if you have one, that will distort your deck speakers.
Power Acoustik PTID-8960
You can Actually get a Single to Double RCA Splitter for this. I think that Wal-Mart Used to Carry them. If not, Any Stereo Install shop has these and will sell them to you. You Might Try Best Buy also. Their Car Audio Install Guys may have one to sell to you.
1helpful
3answers
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
3helpful
Power Acoustik PTID-4005 BYPASS BRAKE
Just ground you brake wire directly to the metal frame. It should work fine. Goodluck.
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
