Posted on Nov 18, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IR 2000 Hi Gurus, I have a Canon IR 2000 printer and gave me System Error E000. I do not know what to do with it. i am in extremly remote environment and to send it to repair it will take months. Anybody has any suggestions? Thanks in advance
  • Tibi Nov 20, 2007
    Thank you for the feedback. it worked fine. I reset it and there is not problem now. Thanks once again!
  • advertising Mar 12, 2008
    My Canon ImageCLASS D861 has a system error E000. How do I resolve the problem myself.
Soulvisitor
Level 3:
  • Master 1,113 Answers
  • Posted on Nov 18, 2007
Soulvisitor
Master
Level 3:
Answers
1113
Questions
0
Helped
929784
Points
3125
Fuser error probally needs fuser replaced and the reset as below
try this
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
or this is explaination of the error and required fix from service manual.
E0000000
The reading of the main thermistor does not reach 30°C 1 sec after the main
power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
Main cause The fixing film unit is faulty. The main thermistor has an open circuit. The
fixing heater has an open circuit. The main power supply PCB is faulty. The
DC controller PCB is faulty.
Caution To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Connector
Is the connector of the fixing assembly connected?
a. main power supply PCB (J8) <-> relay connector <-> heater
b. DC controller PCB (J320) <-> relay connector <-> thermistor
NO: Connect the connector.
2. Fixing film unit (thermistor)
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectosr (4-pin) of the thermistor for electrical continuity. Is it ¥W
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace the fixing film unit.
4. Main power supply PCB, DC controller PCB
Press the Start key. Is the drive voltage of the heater supplied by the connector J8 of the main power supply PCB?
Main heater: between J8-1 (FSR1) and J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM)
YES: The heater drive power supply is faulty. Replace the main power
supply PCB.
NO: The thermistor control mechanism is faulty. Replace the DC controller
PCB.
  • Soulvisitor
    Soulvisitor Nov 20, 2007
    It was the remoteness of your problem that got me motivated I'm in Oz and have done remote, hence you are most welcome and deserving of the fix.
    I find that problems posted with descripitions of circumstances certainly helps my ability (feelability) to solve them.
2helpful
Canon iR 2022 gives a system error E000 and error E003, what could be a problem?
how to clear error code e000 please help me copier ir 2022 show me how to clear
I have canon ir2000 photocopier machine and i t is showing e354
Canon IR 2000 copier is showing System Error E000
From my searches online the first course of action seems to be resetting the printer in service mode.
I attempted to clear it in service mode:
1. Press ADDITIONAL FUNCTIONS, #
2. Go to #7 Printer and press OK
3. Go to #4 Printer Reset and press OK
4. Yes = ( > )
However, when I press the yes (>) nothing happens.
Does anyone know why this is not working?
2helpful
2answers
System error
?SYSTEM ERROR E000? you will need to restart the machine. also check printer board connection if still diplayed
4helpful
2answers
2answers
Please, i don t know to much about copier i have a canon ir 1600 when i powor it after sometime is displaying system error E000 sos please. zakaria
i dont know more abotu copier when the copier on the paper jam error wil displayed how to solve the problem the jam Error Code :0360-0-367596
2helpful
Ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
36helpful
5answers
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
21helpful
4answers
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
1helpful
2answers
Technical suport
I have e000 message on my machine IR 1600
1helpful
3answers
Copier canon ir 1600
Problem with fixing Unit, simple simulation will help. otherwise need to change fixing unit,, contact ur service engineer
k24674
ADMIN Andrew
ADMIN Andrew
