SOURCE: battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
SOURCE: Travel Pro Scooter charging problem.
hi , sounds likek a charger problem but if you have tried another charger then check the charger plug connection where the charger plugs in,
Check the batteries are connected correctly.
Regards
GeWiz.
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
SOURCE: just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
SOURCE: I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
