If you wish to get some details about treadmill repair then check the following link
http://electro-medical.blogspot.com/
SOURCE: cx 1055 service manual
not available service manual free .
you can buy from www.fitnessrepairparts.com
sincerely. God bless you
if the plug is bend or something like. Try with some plyer to repair.Otherwise you need to replace the plug. You can go to www.fitnessrepairparts.com and to buy.
Maybe you will need some electrician,if you do not have the experience.
SOURCE: My NordicTrack CX 998 will not turn on. How do I fix that?
1) Reset the c. breaker from outlet wall from you house.
2) Test the power cord from some wire loose or broken!
3) See the fuse for continuity usethe DVOM or c.breaker tripped, reset.
4) Now you can start. If do not. see for some problem in the filter, coil, or board, you will need the help from some service tech.or electrician.
