Sony DVP-NS305 DVD Player Logo
Zania Posted on Mar 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to burn my own disks, what type of files should i burn to my DVD-R?
Jane
Level 3:
Master:
  • Sony Master 599 Answers
  • Posted on Mar 31, 2020
Jane
Sony Master
Level 3:
Master:
Answers
599
Questions
0
Helped
92633
Points
1869
If you want to burn music to CD, well then this guide may could help: https://bit.ly/3a3kvom
Dexter Abdul
Level 2:
Habit-Forming:
New Friend:
  • Expert 36 Answers
  • Posted on Mar 01, 2016
 Dexter Abdul
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
36
Questions
Helped
6751
Points
116
If you use a CD/DVD burning software like Nero Premium ( I like this one) you can just select what you want to burn (music, video etc) and the program automatically burns the correct file type.
Good luck
tip
Ways to burn Discs with Finder and Disk Utility in Mac (versions OS X 10.4 -...
Without purchasing new disc burning software, there are actually 3 ways to burn CDs & DVDs in your Mac OS X system (Mac OS X 10.3-10.6)
There are methods using Finder and Disk Utility.
Both are easy to do and when set up to use will have you burning music, video, data, and image files (ISO) to CDs or DVDs in no time at all.
BURNING DISKS WITH FINDER
1.) Create a Burn folder and burn a CD/DVD
* The easiest way to burn a disc with Finder is to create a Burn folder with Finder. Here's how you do that:
* Click on any blank space on your desktop and in an instant, Finder will appear on the Apple menu bar next to the Apple menu icon.
• Click on File and select from the drop down menu
* This distinctive folder will now appear on your Desktop
* Now insert a blank CD or DVD and in moments, you will see this window pop up:
• Just click the OK button.
* In a few more moments
on your desktop, you will see this Untitled DVD (or "CD: for CD-ROM Disks) icon:
• Now you can either drag and drop files into the folder, or just double-click the folder and also drag and drop files into the open Burn Folder window
* If you notice, each file you drag (or copy and paste) into the Burn Folder window will have a small curved arrow at the bottom left corner of the file.
That is merely a designation that the file is a image of the actual file and ready to be burned to the CD or DVD you use.
* Notice the Burn button (highlighted in the red box). This is the button you will press, to commence the burn (or copying) of the data you have placed in the burn folder to be copied to disk.
• Click the Burn button, name your disk and that is all it takes. When the process is complete, you will now see a formerly Untitled Disk icon on your desktop replaced with a "Your_new_disc_name" DVD.
(Additional Note: If you wish, you can also simply bypass creating a Burn folder, insert a blank CD or DVD and simply drag and drop or copy and paste files into the open window of the Untitled CD as well.)
BURNING A DISC WITH DISK UTILITY
There are actually two ways to burn data to an DVD or CD with Disk Utility:
1.) Burn a disk in Disk Utility
* Simply open Disk Utility by either clicking anywhere on a blank space on your Desktop window and Finder will appear near your Apple menu, select Go >Utilities and that will take you to the Utilities Folder which is the default location of the Disk Utility application.
* Or you can click the Finder icon on your Dock, open a new Finder window, click on "Applications" listed in the side window and select the Utilities folder
* Either way, you will land here.
• Insert your CD or DVD.
* Once you open Disk Utility, you will see this main window
* Now all you need to do is click the "Burn" button located on the Disk Utility toolbar.
* For an example, I am striving to burn a copy of my Quicken .dmg file to CD.
* Once I have selected the file, then I click the Burn button located at the bottom right corner of the Finder window.
* Follow the onscreen instructions to start the burn process.
2. Creating a multi-session disk using Disk Utility:
Now it is known, that one cannot burn more than once with a single CD-R disc, but it can be done as provide from the knowledge base of Apple support:
  • In the Finder, create a folder for the session and drag the items you want to burn into the folder.
  • In Disk Utility, choose File > New > "Disk Image fromFolder." Then select the folder you created in the dialog and clickOpen.
  • Type a name for the image, choose a disk format, and click Save. Mac OS Extended allows burning the disc more than once. Formats such as ISO allow burning the disc only once.
  • When the disk image is complete, select it in the Disk Utility list and choose images > Burn or click Burn in the toolbar.
  • Insert a blank CD in the optical drive.
  • Select the "Leave disc appendable" checkbox. If you don't see this option, click the triangle in the top-right corner.
  • Click Burn.
What is really nice about this CD/DVD burn feature of DIsk Utility, is that now you can come back later and add more files to the same CD without having to waste all the space on a new CD-R.
This especially useful, if the image file you are need to burn is small in capacity. Just pop the previously burned CD in your drive and add that file or files until that CD is filled to capacity- that is all it takes.
So there you have it, a quick tip on how to use Finder and Disk Utility to burn any data to your CD and DVDs.
Thanks for viewing my Mac OS X tip from FixYa Support. Stay tuned for more tips for how to make the most of your Mac OS X systems!
Regards,
-Mactechtrainer
on Feb 23, 2010 • Computers & Internet
tip
How to burn MTS, M2TS Videos to DVD on Windows 7?
You have .mts/m2ts videos on your HD camcorder and want to burn it to the DVD disk? This tutorial will show you how to burn MTS/M2TS Videos to DVD on Windows 7.
Before we go to step-by-step guide, we need to understand a bit of background knowledge about MTS/M2TS. According to Wikipedia, both MTS and M2TS are Sony high definition video file types, which are raw AVCHD videos recorded by AVCHD camcorders such as Sony HDR-SR1 camcorders. And m2ts files usually record onto 8cm mini DVDS or blue-ray DVDS, SD memory cards and Memory Stick, or record onto hard drive camcorder
So, We have to convert MTS/M2TS videos to DVD video formats (MPEG-2)before we burn it to DVD disk. Fortunately, there is Wondershare DVD Converter Ultimate can burn mts/m2ts video to DVD directly. Importing your MTS/M2TS videos into it and insert a blank DVD disk to DVD Rom, with 1 click, it will bring you a DVD that is playable on your home DVD player. Sounds great? Let's go to the step-by-step guide:
How to burn MTS/M2TS videos to DVD
Step1 Download Wondershare DVD Converter Ultimate, install it and running
Step2 loading videos
Load video files that you want to burn into DVD disk.
Step3 Making a DVD menu
You can select DVD menu template on the left bar. Set background image and music from you local hard disk. Then, click "Next" button
Name DVD label and set video quality and DVD disk type. Click "Start" button. Then, you can take cup of coffee and waiting until it done.
Step4 Burn DVD
That is it, 4 steps to burn videos to DVD and enjoy it on your home DVD player.
on Dec 29, 2009 • Cameras
I need find a free windows vista home premium disk for my laptop
Download the Windows Vista startup disk .ISO file. A .ISO file is a "disk image" file, meaning that it is a compressed archive of all the files that would normally be found on a CD contained in one simple file. Microsoft does not provide users with an official Windows Vista startup disk. Because of this, a number of services online provide their own for users free of charge. Download the .ISO (see Below) file to your computer's desktop. http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/ Put a blank DVD in your computer's DVD writer. Open your DVD burning program. As long as your program can burn .ISO files, you can use any software you'd like. Burn the .ISO file to a DVD by selecting the "File" menu, clicking on "Open" and locating the .ISO file from your hard drive. Next, click the "Burn" button in your DVD burning software and the files contained in the .ISO will be burned to the disk. Label your Windows Vista startup disk with a pen or marker and keep it in a place where you won't lose it. If your computer is damaged to the point where you would need a startup disk, you won't be able to use your computer to make one. It is very important that you do not lose this disk.
How do i take nSCRATCHES OF OF A dvd
there is a white cream called fixi disk or similiar just wipe a small ammount onto the dvd then
you might have to copy the files to a folder then burn the to another disk also there are many cd/dvd freeware recovery programs
http://majorgeeks.com/CD_Recovery_Toolbox_Free_d6668.html CD Recovery Toolbox Free was developed for recovering damaged files from different disk types: CD, DVD, HD DVD, Blu-Ray, etc.
http://majorgeeks.com/Unstoppable_Copier_d2623.html This program is great for recovering files from scratched CD
2answers
I want to save my picture files on the cd or dvd tape but i cant transfer it.
You need a burning software to burn your picture files, music, or video.
You can use NERO Burning ROM. Download it from HERE. You can use the "Data Burning" Feature in it to transfer your files into CD or DVD.
1helpful
Transfered pics to DVD ,will not play through my dvd player to tv. Do I need to re-format and how/?
There could be a few problems here. First, different video players only accept certain types of disks that you can burn on. The older the player, the fewer options there will likely be.
DVD Players also only read certain types of files. So, there is no one way to tell what to use without first knowing the dvd player make and model. Common file types that are acceptable for pictures are jpg and gif. Jpeg is a universal type file, and it can be edited in almost any program.
After you find out what kinds of image files your player can read, your best bet is to use whatever software that came with your dvd burner.
The older the burner, the more likely it will be that you have to use the software that came with it. It would be under programs, and if you are not a frequent user, you may never even have opened the software.
Ugh, right? Media Player will also burn pictures to dvds, and you can even use my computer to burn pictures as long as you have them saved in the right file type.
If you are using dvd r disks, you have to finish or finalize them before trying to play them. Recording on those is a one shot deal.
I am trying to copy the DVD I finalized in the Canan DC210 to ano
Simple way if you have two dvd trays in your computer: just pop in the mini-disk in one tray and load a DVD+r, or DVD-r recordable disk in the tray of the DVD burner. Use the burning software that is available on your computer to "copy the disk".Other way:Just popin your mini-dvd into your computer and drag and copy the file folder (video_ts folder)onto your hard drive. Now, use dvd burning software that supports DVD images. I use the free ImgBurn program from: http://www.videohelp.com/tools/ImgBurn. (Remember, use "build mode" within ImgBurn to create the "DVD image" that the program will burn to disk.Disregard all the terminology if you don't understand it. ImgBurn is very simple to use. I mention "DVD image" because the conventional type of disk burning (copying documents, photos, etc. on disk) will just create a "data disk" with files on it. Video files burned in this way will play on computers but not on all stand alone DVD players.
2answers
Burned Dvds
1.Have you finalized the discs?
2. have you checked the disk type the various players will accommodate not all machine will play all disks - this is particularly the case with CD/DVD - RW's
The read appropriate manuals
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
