Easy Uninstaller is pretty straightforward to use. Launch the app and it will show all the installed apps in alphabetical order. There's a checkmark next to each app name. Scroll your way through and mark all the apps you want to uninstall.
Now click the Uninstall button at the bottom. There will be a confirmation popup, you'll have to tap OK for every app you want to uninstall. Easy Uninstaller will also look for additional files that an uninstalling app is leaving behind and will ask you if you want to delete those as well. It's a good feature for apps that download a lot of their own content to the internal storage. Or you might also use this thing
How to Hack Snapchat App Secretly
Uninstall, disable, and delete apps
You can remove apps from your device if you don't want them anymore or you need to clear memory space. If you uninstall an app you paid for, you can reinstall it later without buying it again.
Uninstall or disable apps
Uninstall vs. disable
There are two ways to remove apps depending on whether you downloaded the app or if it came preinstalled on your device:
Note: Disabling a system app may cause other apps to misbehave and will delete your associated data for that app.
Snapchat application for Android and iPhone Device. Snapchat add features to send pictures and messages two other peoples on the application. this application one of the most trusted social media application. where people can share information and send pictures and messages without the risk of them showing it to anyone else.
