pride corporate headquarters are 182 susquehana avenue exeter
PA 18643
phone 1-800-800-8586 [email protected]
call them on the phone and ask for the nearest service agent to your location or failing that talk to the spares department and see if you can get the parts you want
Pride MobilityHelp Me Choose · Where to Buy · Request to Be Contacted · View all Models. Pride Mobility Scooters ... Power Chair Consumer Safety Guide .... Version / Date. Flash. C 01/04. Pride LX Series. C 05/08. Z-11. B 07/04. Manual Wheelchair ... Travel Scooter Throttle Control Lever Operation Product Insert ... Victory 9/Victory 10 ...
Hi If the brake is getting hot then it's possible for a faulty brake or faulty controller , firslty check the wring to the brake , check that there isn't a loose connection from the controller to the brake.. i do recommend that you stop using the scooter until this is sorted...
Hi, Sounds like a loose connection from the controller to the motor, now check the wire leading to the motor, two for the motor and two for the brake, the brake wires being the thinnest....
Throttle potentiometers are a frequent part that is replaced on scooters due to wear. This part is available from the manufacturer Pride or from a company called Monsterscooterparts.com.
At the Monsterscooterparts home page click on mobility scooter parts, pride scooters, pride parts click on Pride Victory XL SC270 , select throttle pot assembly. Verify SN and compatibility remarks. They have an 800 phone number for questions and they ship worldwide. The Pride part number is ELEASMB 1511 for Victory XL 4 wheel scooters after the year 2000. Looks like the price is about $80. Labor is about 1/2 hour and can be done by an experienced mechanic or do-it-yourself. The part is available from the manufacturer if you are a dealer or have an account.
First remove the throttle lever by loosening the allen set screws. Separate the front console covers by removing 8 or more screws holding it together. Locate the throttle pot, unplug it and install a new one. Be careful not to over-tighten or strip the screws holding the potentiometer housing tabs to the plastic. Check the alignment visually before reassembling it. Don't pinch any wiring when you put the console back together. When you reinstall the throttle lever make sure it is even left to right and does not bind on the plastic console housing. Tighten the lever set screws firmly but do not strip them, this repair will need to be done again and you want to be able to remove these set screws. Hope this helps.
