SOURCE: phones won't ring
Your memory battery on your telephone system is bad. when power is lost , so is the programming. to fix this , you must go into system programming. From any phone, without picking up the handset. Press #20 Dial 12341, Press #. Press # again and dial 62, Press Line 1 and then press the button of each stn you want to ring ,( The display will show 1 if you press stn 1 and so on.) program each line the same way.
SOURCE: Samsung iDCS 18D - red light keep on flashing, cannot cancel
The User guide for Samsung iDCS 18D
http://www.a1bizcom.com/files/idcs16ug.pdf
SOURCE: samsung prostar 816 plus system ringing problem
sounds like your having a couple of problems at the same time. the lines only ringing at station 1 is the default setting of the system my guess is that the time and date are also way off if thats the case.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
next, the problem with the cordless not working has to do with the port programming, in default it assigns all ports as multiline sets.
To assign a SLT(single line telephone) port to the system while still in program mode dial #38 the screen should say slt dial type and then 16 0's.
0 = keyset 1=slt set
enter in all 16 digits followed by the # i.e.if your cordless is on port 7 it would look like 0000001000000000 #
lastly the phone that can no lnger recieve calls sounds like the do not disturb or DND has been pressed to stop the alarm from ringing. press the mute/dnd button (light should be off). to cancel an alarm press the ALM/SD button twice and then the hold button.
hope that helps out.
Dial transfer, dial 505.
You'll be promted to enter the new date and time.
Dial transfer to save and exit.
SOURCE: Cannot set the time and
HI, i got
the scoop on how to change the date and time. first while handset is
on hook press TRSF then dial 200 Dial 1234 the display shows enable
cus prog dial 1 to enable then press TRSF To change the date and
time from here out press TRSF and dial 505 the display will show :
(this is an example)
old: 6010104:0047
new:WMMDDYY:HHMM
Enter the new time and date using the above format and the system will
return to step 2. Verify the time and date and re enter if necessary
Press TRSF to store and exit. or press SPK to store and advance to the
next program.
Hope it helped....
Good luck..
