Exercise & Fitness Logo
k
kalimullah Posted on Feb 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TRUE Fitness 825 suddenly stops and after some seconds shown errors E5( sensor error)what would be the cause of suddenly stop ?
Electro Med Services
Level 3:
  • TRUE Fitness... Master 6,694 Answers
  • Posted on Mar 01, 2016
Level 3:
Answers
6694
Questions
Helped
1871018
Points
21433
Can be the speed sensor or the motor driver is faulty.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Error E5 in DK-01A treadmill. I was using it and suddenly it stopped.
Question moved from Microwave Oven category.
This is a virtually unknown make made in Taiwan by
YIJIAN
. This link might work better for wherever you live.
https://www.google.com/search?q=DK-01A+treadmill+error+E5
1helpful
I have a true 700 treadmill with a e5
E5 is the error code for the speed sensor. It should be cleaned and centered if located off the back of the motor. If close to the front roller, 1/8th inch away from the magnet.
As the alternatives are bad sensor, bad motor, or bad motor control board, you have to eliminate each as a cause. Manually push the walk belt and see if there is a blinking light on the motor control board. If the sensor and motor are good, you may need to replace the motor control board. A bad motor is an expensive replacement.
Jazfit Top49 treadmill. What does E5 indicate?
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.lifespanfitness.com/fitness/resources/articles/what-does-your-treadmills-error-code-mean&ved=2ahUKEwjgxbb2nOXsAhUQmxQKHQZgBd4QFjAAegQIARAB&usg=AOvVaw0R9ksJqwrHV5DZhsr4FPrv
What is the E2 error on extera 2500 treadmill.... it just stops... very dangerous !
This is a speed sensor error. Unplug the unit then remove the motor shroud
1helpful
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
2helpful
2answers
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Top TRUE Fitness Technology Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a TRUE Fitness Technology Exercise and Fitnes Expert? Answer questions, earn points and help others
