SOURCE: flashing security light in dash
pontiacs have a security key do you have another key you can try to make sure this is not the problem ?
SOURCE: My Sym Joyride 180 cuts out when I slow down
If this happens in cold weather or after a fast run it's carb icing. SYM do a replacement carb bowl to solve this or you can use a fuel additive SILKOLENE Pro FST. I use the additive as it also keeps the fule system clean and lasts well.
SOURCE: my sym joyride 200 is somewhat like dragging at
I also own one (4 years old). Assuming it drives strongly enough at speed the problem will be your belt drive/variator transmission. If you are OK mechanic-wise remove the left side panel (you have to remove the small rear panel near the lights first) and then all the txmission case screws to have a look. If the belt is OK (and they last forever) it could be you need new roller weights in the front variator. They wear flat spots afet a couple of years that ruin acceleration. (Special tool needed - I made one though), or new clutch shoes in the rear variator - or maybe they are just sticking and need a good clean. Spin everything by hand to check for noise/slop/ wobbliness and check the oil in the tiny rear gearbox (see owners handbook. You need a measuring cup and a paint syringe to get the exact amount right.
If you aren't confident use a good bike garage. weights are inexpensive and probably clutch shoes too so if you can do any labour yourself it won't break the bank. Google for a free SYM Joyride workshop manual by the way. Happy scootering
SOURCE: Car will not start- will crank- anti-theft light
try a diffrent key,your extra one.Could be the micro-chip inside is not comunication with anti-theft-.This happened to me.I used the spare set for a few days .then the other key started working again
SOURCE: need to access battery on sym joyride 200
If it is leaking battery acid you should be able to work out where the battery is. Because you can see where the electrolyte is coming from. Remember to disconnect the earth wire (black) first. Remember to neutralise the battery acid after you have removed the failed battery.
