I love this fridge, 970-618240 works awesome. It deserves repair/replacement parts, so want to exhaust all avenues. I can't seem to find help in locating a gasket/seal only failed searches. If I measure the existing gasket/seal, look for kenmore brand, are they universal?
SOURCE: water coming from under door
The water line enters door thru lower hinge. Check the connection by door hinge. Remove toeplate to access this.
SOURCE: Kenmore Fridge- all lights blinking
sorry to say this but the mother board has took a hit replace this and all will be well
SOURCE: Kenmore 10654382300 side by side
Hi Vince,
Thanks for the posting in FIXYA.
Please repair the Freezer door as it is not sealing, due to which cooling is affected. If it is under warranty then contact to the manufacturer as soon as possible.
Regards
ELLIN
SOURCE: Water dispenser not working on my Kenmore fridge
NO,YOUR RIGHT YOU NEED TO REPLACE THE WATER INLET VALVE ON THE LOWER BACK OF FRIG.-MIKE
SOURCE: my Kenmore black mini fridge, door will not stay sealed shut
Got too much stuff in it.
Not level or is tilted forward.
Door is warped.
You keep opening it.
Am I getting close?
