SOURCE: no water coming out of carver cascade water heater
is the cold side hooked to the cold side if not you will be feeding the unit backwars making it to where the cold is just comming across the top of the tank, check the dip tube also, this makes the cold water go to the bottom and push the hot out of its outlet,, how many faucets are involved, if just one might want to check the cartridge to make sure it is working properly
SOURCE: low pressure on hot water taps and showers
Many states building codes require a pressure regulator and expansion tank for hot water heater installation. Check the pressure regulator if you have one as this would only affect the hot water pressure. Adjust or replace. Rap the expansion tank like knocking hard on a door. Hollow sound is good. Dull thud means it needs to be replaced as it is filled with water.
SOURCE: I have a thermostat mixer shower but hot water has
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
SOURCE: turned off the hot water
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating. New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
