I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced. Regards,Richard
I have the same problem and sent an e-mail to DACOR. A James Carlos responded and advised that DACOR could not provide DYI info because of liability problems, pure BS in my opinion. I've had problems with a DACOR microwave (manuf. by Sharp), my DACOR wall oven Model ECS103 and my DACOR Raised Vent system and told Mr. Carlos so. I don't know how to fix the blinking oven light other than cutting power at the circuit breaker panel or removing the two light bulbs which other have advised but suspect a new front control panel is required. If you find a fix, please advise me at [email protected]. I think DACOR products are overpriced and junk.
Hi. I recommend Checking the sensor wiring harness and harness connection between the oven sensor and oven control.
Replace the oven temperature sensor (RTD) if wiring is ok.
EUREKA! I found the reset button and my oven is heating as we speak. Ok, open the oven door. there is a thin panel with vents right at the door latch. Unscrew the (6) screws and pull off the panel. There is a red button on the left back behind the wiring. GOOD LUCK!
Hi, Dacor has a Technical Manual that may help you with your problem. It has a ECS wall mount oven but does not list a ECPS. Is your listing of the model correct? Here is a link to download the Technical Manual. https://www.scribd.com/doc/14008662/Dacor-Technical-Manual
Hope it helps.
the problem was fixed by opening the panel between the oven cavity and the touch panel just behinf the door. you can look through the grill but to trip the reset you must unscrew the panel. you will find the reset back behind the wires Looks a red button nestled on top not very open but it should be there> i do have to say i found a step by step description on this site. but right now i can't tell you who exactly he was.
The fix is replacing the mebrane panel. Recent poster advised they where able to get Dacor to send a new panel and they would install (it's not difficult). I bought one online for around $175 and installed myself. Do a search for details.
