Disassemble instructions
SOURCE: re-assembling my Wahl Beard Trimmer Model # 9918C
Turn the trimmer off. Put your thumb under the teeth of the attachment. Push Up. The attachment should snap off. Replace the beard trimmer in the slot. Hope this helps.
SOURCE: How to attach beard regulator on Wahl Groomsman
The attachment should hook over the teeth of the blades and then snap onto the back end.
SOURCE: this is a very good shaving machine and i want another one
Wahl Clipper Corp
2900 N. Locust St.
Sterling, IL 61081
USA
815-625-6525
SOURCE: I lost my instruction manual. How do you oil the
Oiling the trimmer is very simple. It is only necessary to apply oil to the blades. Simply apply one or two drops of oil directly to the blades while running. This should be done before each use.
You should have gotten a bottle of the blade oil with your clipper. If you have also lost this, you can buy a bottle of Wahl clipper oil from shaveroutlet.com. see link below
http://shaveroutlet.com/wahl-4oz-squeeze-bottle-clipper-oil-p-584.html
SOURCE: How do I split the case of my Wahl 9916C beard
Bottom side (black on mine) has a finger grove section that comes off with a small flat blade screw driver used to pry up, 4 tabs, one on each corner (Exposes 2 screws). Need a sauder (spelling not my thing) gun to remove and batteries are 2 ea 1.2 v (looks between AA & AAA size). I'm just going to just buy another unit. Good luck!
