Peg Perego Vespa Scooter Logo
b
brian davis Posted on Feb 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dead battery, charged battery now won't start, loud bang when when turned key on
Adam Fjeld
Level 3:
Genius:
  • Peg Perego Master 1,508 Answers
  • Posted on Aug 18, 2017
Adam Fjeld
Peg Perego Master
Level 3:
Genius:
Answers
1508
Questions
0
Helped
542655
Points
1761
Most likely need new batteries, if there was a bang, i'd check to make sure one of the batteries didn't explode
1helpful
I have a 2009 Toyota Corolla LE no power to certain fuses and circuit fuses are good car cranks but won't start
double posted and tests DONE WRONG
the battery must not be dead is first
and not testing fuse, with KEY on,
1;/2 the fuses are dead KEY off that is 100% Normal.
key on does IP cluster glow lamps as it did just like it did for 13 years?
head lamps bright key on an off both, (it must)
heater blower on high, works loud ,key on,
is the starter motor dead/? called cranking,?????????????
you said new crank , I'm sure you meant a new starter motor>?
is the starter dead? now? if yes post how to test a dead starter.
starters fail in many ways.
  • dead
  • chatters.
  • clicks,
  • makes a HUGE nasty loud bang, (engine or it seized)
  • or starter spins fast (sounds like sewing machined) but engine cranks shaft never spins (turns ) starter pinon failure.
or starter goes GRRRRRGRRRRRR and crank shaft spins but does not start.(seen and heard)
a dead starter with a good battery (charged) may crank
if you learn to crank it in NEUTRAL. (auto tranny?)
does starter work , JUMPER cable jump started?????
crank in park then try Neutral.
on stick shift cars the clutch switch bad kills cranking.
1helpful
Automotive electrical problem
Daniel, If battery is known to be good, could be bad connections at battery, starter/solenoid, or ground on engine/frame, battery cables also could be bad with build up of corrosion internally. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Engine Won Crank or Start
Diagnostic flowchart for car that won start or stalls Troubleshooting for...
No Crank No Start Diagnosis EricTheCarGuy
I Ask a Mechanic to change Starter and now most light are dead.
i would say check all the fuses again, both in passenger compartment and under the hood. plus, the mechanic should be responsible for this issue. it also sounds like you battery is not fully charged. i would also suspect, the starter was changed without disconnecting the battery and something was shorted as he installed the starter. good luck
2009 ford focus won't start
Your battery is most likely dead if your lights go out. Charge or change your battery, but your altenater maybe be bad. It recharges your battery, if it don't work your battery will die..
2helpful
2answers
2002 Suburban clicks when trying to start.
Yes it could be your starter the fact that you hear the click tells you that the starter solenoid is in fact working. Do check your connections for looseness or corrosion prior to starter replacement and fix as needed. Possibly has a dead spot on the starter that won't allow starter motor to turn even though the solenoid engages.
1992 toyota pickup won't start and battery won't charge
Sounds like your battery is just too dead, has enough juice to light up the system for a minute but cranking drains it and if it wont charge then deff fried, you could try removing the battery and starting the car with cables to confirm the starter still works. If a bettery is too dead then when you are jumping it, it takes to much of the power just trying to get through the battery.
1helpful
2answers
Daihatsu charade Jan 1994 won't start. Turn key to
have you checked the battery connections, or charge-up battery if dead
Charged battery up for bike because would not start
?.....was the bang when you tried to start the bike...or as you turned ignition on?...if when you turned ignition on sounds like you need to check wireing...if bang was when you truned eneing over it could be unburt petrol that banged when bike tried to fire up !!...
4helpful
Mower will not start. Makes a loud fast clicking noise when the key is turned.
Loud ticking usually indicates near dead battery, take it out and charge it. If it still ticks you may need to replace it as they are only good for a few years.
Top Peg Perego Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
