Hi Felicia, The link below is a short youtube video showing how to test and fix a car that shuts off randomly, Hope this helps.....CHEERS..
Fixing Car That Shuts Off Randomly
SOURCE: Check Engine light on Acura TL 3.2 1999
You can turn off the Check Engine light by either disconnecting the battery or by using a code reader to clear the codes. However, if the problem still exists it will come right back on. Instead you should get the code read, find out what the problem is, and fix it. Your local autozone or checker auto parts store will read them for free.
SOURCE: engine revs up and down
Sounds like a bad IAC motor, or a vaccuum leak, or low coolant... I would definately start with checking these things first
SOURCE: How do you reset the check engine light on an Acura TL 1999
i dont know how else to do it other than with a diagnostic tester. i think that may be the only way.
SOURCE: My 97 Acura 3.2 TL starts to overheat and I also
how can i fix a overheating on a acura tl 1997 3.2
SOURCE: where is plug in acura 2000 tl for check engine
The OBDII connector is located in the center console just behind the ashtray. There is a plastic cover that must be removed and you will find the connector behind the cover.
