No electrical power 1994 S10 Pickup V-6 4.3 L
your fuse box is inside , lower left kick panel , check all fuses in
there , then also in the engine compartment on the firewall around the
middle is a junction block with like 2 fusible links , they need to be tested , and also 1 fusible
link right off the positive side of the battery , test it also , if you
don't have a test light for testing , you can kinda wiggle the fusible
links and feel if they are limp and stretchy , that's
not a good sign , you can buy replacement fusible links or fusible link
wire from local parts store , depending on how much sparking happened
you may have blown the fusible links . if you don't have a test light , pick one up at the parts house and learn to use it , it will be invaluable when it comes to testing this kinda of failure . cheers .
