SOURCE: hyundai santa fe 03 running problems
If your Santa Fe has a V6 engine 2.7L , it sounds like you have an ignition break down happening. You will need to renew all the ignition wires and check the two coils also for arcing .
SOURCE: ''check engine light'' illuminated, 1004 Hyundai, Santa Fe
If you live in the US, take it to qany Auto Zone store and thy will read the codes off for you, I would suspect any right thinking competitor would do the same, check if you don't have one near by.
Hope this is of some help.
Ed
SOURCE: PROGRAM KEYFOB FOR HYUNDAI SANTA FE
This is from the factory service manual of your car:
There is no onboard programming procedure for this vehicle. This vehicle requires special equipment be connected to the vehicle to program the keyless remote. Translation you need the dealer to do this.
SOURCE: I have a 05' Hyundai Santa Fe.The ABS light & TCS light.
dear friend-it sounds like one of the sensors(wheel)is faulty or one pne of the turnwheels came loose.
SOURCE: Change serpentine belt 2004 Hyundai Santa Fe
it uses a spring loaded tensioner.use a breaker bar to rotate the tension and it should just come off.if u need a pic or anything else to do it let me know,
