Question about Electrical Supplies
We have a Maxa ER 5000 Tecumseh Generator, changed the oil and spark plug, no fire. How do you check the low oil switch?
It ran before we changed plug and oil, now it won't start. how do you reset or check the low oil off switch?
    Top Expert:
  • 11,573 Answers
Nancy, If you think this is the problem, simply unplug it. See links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Disconnect Your Low Oil Sensor
Re Testing Low Oil Sensor on Honda GX Engine
How to Test the Low Oil Pressure Switch on Generator
Generator runs then shuts off
Posted on Feb 26, 2016
SOURCE:
I have a coleman maxa 5000 generator no spark
first look at the oil level some generators have a low oil shut off then remove the front cover of the engine and unplug the small wire on the side of the coil then try to start it if you get spark back the its a wire problem if still no spark then the coil is bad
Aug 15, 2012 | Coleman Powermate Powermate 5000W...
I cant get my coleman powermate 5000 MAXA ER to start. i have changed the oil, refilled the gas, changed the spark plug, and tried using starter fluid. what else can i try?
It's almost certainly gummed up gas in the carburetor. Get some carb cleaner, and some spray instant start. Drain the gas from the tank and put a small amount of 50/50 carb cleaner and gas in the tank. Remove the air cleaner, open the choke, spray a little instant start into the carb and start it. It may fire just a couple of time. Keep the choke on to try to pull a bit of gas through the carb. You may have to do this a few times. Once you can tell some gas is flowing, open the choke slowly to keep it running until you use up the 50/50 mix. Then try a small amount of straight gas in the tank to be sure it works right, before you refill the tank. Make sure you use a stabilizing additive in any gas that you store for more than a month. good luck, Al K
Feb 02, 2011 | Coleman Powermate Premium Plus 6250W...
Coleman powermate maxa 5000 er - been sitting for about 2 years and I want to start it up again. Checked oil, ok. added new gas (but did not drain old). Fuel valve open, spark plug cap on. Engine won't...
it could have sezed up on you take out the plug and try to turn the motor by hand if it wont turn its sezed up,,,if so all you can do is tip down the plug hole a small brop of red x or two stroke oil and rock the motor back and frow till it frees off,,
if it frees off that is!
Aug 30, 2010 | Electrical Supplies
Powermate Maxa 5000 er will not run stably
Check the fuel filter. My company designed hybrid generators that are far more efficient. They use batteries to power your equipment, and the generator runs intermittantly to recharge the batteries when needed.
If you would like to convert to hybrid, contact me at buffalonymann@yahoo.com
Sep 24, 2009 | Coleman Electrical Supplies
Electrical Supplies Logo
369 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
