Question about Whirlpool LGB6300 Gas Dryer
Runs but not getting hot - Whirlpool LGB6300 Gas Dryer
    Habit-Forming:
  • 111 Answers
Check the gas supply pressure. if not within required pressure consult the gas company. if there is no problem with gas pressure get to the back of the unit to check the fuse for the gas solenoid valve that controls the flow of the gas. if solenoid valve is faulty, replace it with a good one . . if after installing a new solenoid valve unit still does not kick in , check the igniter . replace with a good one if it is broken , the unit should produce heat now .thanks.
Posted on Mar 04, 2016
SOURCE:
What is the function of the ignition switch in a 1987 Ford Ranger 2.9.Tested wires under column. Had no power to some that should have been hot and truck still started? What is up with that?
there is only one hot wire
in the accessories position there will be a hot wire
in the run position there will be another hot wire
in the start position there will be another hot wire
accessories runs the radio fans, cig lighter etc
the run position runs coil and all accessories
start runs coil and starter motor /relay
Sep 05, 2018 | Ford Cars & Trucks
Shower takes too long to get hot then runs lukewarm then hot lukewarm then gets cooler & and cooler &cold
There is a temperature adjustment on the hot water tank.
Perhaps it is set too low. They are often red in color.
Feb 24, 2016 | Home
95 Gran am engine lith blinks and exaust pipe gets red hot runs rough
Should be your catalytic converter is plugged up.
should be replaced
Jun 25, 2012 | Cars & Trucks
Car not starting after car runs for a while and weather is hot
have the starter tested because it sounds like a bad solenoid in the starter and it makes it get hot so it won't start
Apr 26, 2009 | 1991 Lincoln Town Car
Whirlpool LGB6300 Gas Dryer Logo
128 people viewed this question
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
