Maytag Neptune MAH9700 Front Load Washer Logo
Kimberly Knott Posted on Feb 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Maytag front load washer , powers up and lets me change the settings, but when I press the start button , it beeps and displays d5 and wont start??
J.D. Browning
Level 3:
  • Maytag Master 2,760 Answers
  • Posted on Feb 26, 2016
J.D. Browning
Maytag Master
Level 3:
Answers
2760
Questions
0
Helped
1015122
Points
6696
This fault code ind a door lock problem ,hence this is why it wont start , it thinks the door is not closed , id say the door latch mech. needs service
I get a PF error. That goes away and shows 52 in the display. The buttons light up, but pressing any buttons does nothing but to make 3 beeps.
PF is Power Fail, means the Power was cut off. PF Power failure Power to the machine has been lost during the last cycle. This may occur on start up of a new machine due to factory testing.
We have a maytag neptune washer and on evey setting, it's telling us d5 - what does it mean?
D5 means blocked coin 1 or coin drop control circuit failure, coin recognition and price display disabled while blockage persists.
MAYTAG MAH5500BWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Display showing d5?
d5 - door is open when washer is running.
or the door switch is bad.
Wont start
Try unplugging the unit for an hour allowing the microprocessor to reset. Plug it back in and use as normal. Let me know if this helps.
Waiting to hear from you,
Eric Campion
1helpful
Maytag neptune front load washer wont start when button pressed
This is joyce
first lets start simple unplug the machine and leave unpluged for 1 min. replug back, see if this solves the problem.
thanks,
joyce
Machine beeps but won't start
does it say do in the display as if the door is open??
All buttons cause machine to beep
Trying unplugging for 20 minutes maybe you can reset it.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
