I have Acer Aspire 5349 its shows plug in not charging. I have replaced the battery still plug in not charging. How do i troubleshoot.
SOURCE: Acer Aspire 3680
My daughters laptop was doing the same thing. No power indicator light or battery wasnt charging, but the charger was putting out ok. Found on the laptop were the power adapter plugs in the center
plug pin was broke off in the plug of the adapter making it look like a new syle special plug, Had to change the female recept. on the back of the computer.
SOURCE: Acer Aspire 2920 won't turn on, although plugged in with battery
First of all, what I'm about to tell you are general troubleshooting techniques - I make no claim that they will fix what you describe, but they may help lead you to a solution.
I hope you 'see the light'. Good Luck!
SOURCE: I Acer Aspire 5310 cant charge battery unless the
you hav to change the chager you are using
SOURCE: Got new battery for acer aspire 6920. not charging
You ordered the wrong battery, theres two types, your original would have been 11.1v if you check the new one it will be 14.8v. They are not compatable.
SOURCE: when my acer aspire 5734z
It is a sign that your battery is failing. Try to remove the battery then put it back. After that, try to check if you still experience the same thing. If so, then you need a new battery replacement.
Batteries usually start to degrade after a year or after 500 charges, whichever comes first.
