There is an automatic shut off which is proramable by holding the pwr button until the display blinks. The problem is the display never blinks so i cannot change the automatic shutoff time.
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting: Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting button until the correct hour is displayed. Press Select to set the hour shown. The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select to set the minutes shown. The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select. The Year will blink. Press the Setting button until the desired year is shown. Press Select to set the year shown. The Month will blink. Press Setting until the correct month is shown. Press Select to set the month shown. The Day blinks. Press Setting until the correct day is shown. Press Select to set the day shown. Print Method: Press the Mode button until P5 (Program Mode 5 for Print Format) is displayed. Press Setting to choose one of the following Print Methods. The TC100 has two settings for print activation: Manual or Automatic 1 = Automatic (default setting) - The TC100 automatically prints when the time card is inserted. 2 = Manual - After inserting the time card, press the Print Button to activate printing. Press Select to confirm the Print Method chosen. Press Mode to return to normal operational. hope this Help : - )
this should fix your problem
HOW TO USE YOUR TC100 TIME CLOCK
Step 1: Remove the front cover - see enclosed instruction sheet on page 5.
Step 2: Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting:
the month shown.
shown.
card is inserted.
printing.
Set the display to time by pressing the tittle button. once time is displayed, press tittle button and hold until the time starts blinking. now adjust hour using arrow keys. now press mode once and use arrow keys for adjusting minutes. press mode again. now the time is set.
Goto menu and set PWR ON. this could be set to PWR OFF accidentally.
cheers Alex Victor
You will have to reset the maintance light. Turn the key in the on position.( Not the crank position ) Push the trip meter button until you see the mileage reading. Now turn key off and with left hand hold in trip button. While holding in the button with left hand turn key to on position until you see dash lights. Hold button in until light starts to blink then after 4 blinks release button for 4 blinks then hold in again until light resets. If it doesn't work try trip A instead of mileage reading.
Should have oil in it. I don't think you can refill it. If it has leaked out, it's probably no good. Anyway, here are the instructions.
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off. Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature. The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear. Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear. Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn on when time expires.
Set temperature:
