Hello Charles, thank you for your submission!
I understand that the element on your Frigidaire range burns high on a medium setting and it has been recently replaced. This could be a possible problem with the wiring harness or switch inside of the range. Since it could be anyone of these underlying issues I would strongly recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this information can be helpful towards your repair. -Matt
SOURCE: Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove. Must be a constant 220. Let me know what you find.
SOURCE: need color code/wiring diagram info for Enterprise electric range installation of thermostat
I need the Oven knob for the front panel. The numbers have rubbed off on mine. Thanks, in advance, for your help!
SOURCE: Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
SOURCE: heating element stays on when turned off
The thermostat (that is the dial that you turn to energize the heating elements) is the only thing that connects power to and disconnects power from the heating element. It is bad.
You can unplug the unit and remove the thermostat. Take it to a parts supplier and get a new one and install it. Your problem will go away.
If you would like to see a wiring diagram...click on this link:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255301.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
