I had a Wolf 30F wall oven with a similar problem after power outage. It wouldnt stop beeping with error message related to temperature control. My solution was to turn power of at circuit panel, then reset by pressing and holding the clear button for 5 seconds.
Also note: in my case I had to close the display before switching the panel off. When I tried to the reset process with the panel showing, it wouldn\'t reset.
To reset other various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set the 12-hour clock to the current time of day. It may need to be reset after a prolonged power failure. The clock is visible on the control panel during all modes. If the upper oven timer is set, the clock will not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to set current time of day.
3) Touch CLOCK or ENTER to start clock.
24-HOUR CLOCK
The time-of-day clock can be changed from a 12-hour clock to a 24-hour clock. After the clock has been set, touch TEMPERATURE for three seconds, touch CLOCK, and then touch ENTER. Follow the same sequence to change back to the standard 12-hour clock setting.
Fahrenheit to Celsius
The oven can be changed from Fahrenheit (°F) temperature to Celsius (°C).
If you arentt seeing any display then first check the main power supply. if you see display and the temperature not going up then there is an switch at the back of oven(red color). if its already seems pressed then you have another problem. please let me know if you have another problem thanks please rate my work
THERE IS A PROBLE WITH THE ERC (CLOCK) NOT TO SURE IF I WOULD USE IT EITHER. THE PART IS EASY TO CHANGE JUST TURN POWER OFF AT THE BREAKER FIRST. YOU CAN FIND THIS PART HERE. http://www.searspartsdirect.com/partsdirec
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
When I turn on my westinghouse gas oven (GOL476), it appears to ignite immediately but after 3 or 4 minutes there is a strong gas smell which lasts for sometime before it gradually disappears.
