Washing Machines Logo
Lynne Saint Posted on Feb 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What settings do I use to wash and dry mixed fabric load?
2wsx
Level 2:
  • Expert 128 Answers
  • Posted on Feb 25, 2016
2wsx
Expert
Level 2:
Answers
128
Questions
Helped
32881
Points
258
Since it's hard to say, what is mixed fabric , just for sure use low temperature for washing and also low temperature for drying
What is the best settings to wash jeans on.
While hand washing and line drying is safest, it's also costly in terms of time and effort. Unless your jeans are particularly dirty, it's best to wash them in cold water, select one of the gentler cycles, and dry them at a low temperature. Special detergents formulated to preserve dark colors really do work.
What temperature do you wash jeans? When to Use Warm Water - For man-made fibers, knits and jeans, use warm water (90°F). Most of your clothes can be washed in warm water. It offers good cleaning without significant fading or shrinking. When to Use Cold Water - For dark, bright colors that bleed or delicate fabrics, use cold water (80°F).
Wash your jeans in the sink or a tub.
  1. Fill a tub with a few inches of cold or lukewarm water. Mix in a gentle, color preserving detergent.
  2. Turn the jeans inside out, then lay flat in the tub. Don't bunch them or wrinkle them. Let them soak for about 45 minutes.
  3. Run them under the water to rinse. Hang up to dry.
  4. Can you put jeans in a tumble dryer?
    According to Good Housekeeping "All fabrics and especially jeans benefit when youtake them out of the dryer slightly damp. ... If, even after tumbling on low heat and a delicate cycle, you see lots of lint on the dryer's filter, you may want to switch to linedrying your jeans to help preserve the fabric.
    hope this helps you out.
2answers
What settings do I use to wash and dry a load of mixed fabrics?
Normal wash cycle
cold wash
warm rinse
Hope this helps
How can I get a shorter wash on the Logixx7. Every wash is lasting at least 3hrs!!!!!!!!.
Hi dear,
I do not know what type or model of your washer but those LOGIXX series should have a INTENSIVE wash button. Make sure that button not active when you setting your program by default and you are not over loading your machine. You need to use specific program for specific wash load. Example: Let's say your machine has 7Kg dry weight wash capacity. That's indication for Cotton Fabric Only. Your machine able to wash 7Kg Cotton fabric but it can not able to wash 7Kg WOOL, Dedicates, Jeans etc. Refer your machine's user manual. I hope that helps. Thanks.
What is the max load for an indesit 1234T washing machine please x
  • From the manual
    Maximum dry laundry
    load
    heavy fabrics
    maximum 5 kg
    delicate fabrics
    maximum 2 kg
    pure new wool
    maximum 1 kg
    mixed loads
    maximum 2,5 kg
    How heavy is your
    laundry?
    1 sheet 400-500 g
    1 pillow case 150-200 g
    1 table cloth 400-500 g
    1 bathrobe 900-1200 g
    1 bathroom towel150-250 g
Hello i have a quinny buzz 3 and will like to wash the seat. dont know if i should put it in a washing machine pls.
Good Morning
Spot cleaning should be done by mixing warm water with a mild handwash detergent and using a clean sponge on the fabric taking care not to make it too wet as this may cause water marks.
If you really want to wash the whole fabric you can do so; Remove it from the sub seat (seat frame) to wash. Handwash is best, but if you have a handwash or delicate cycle on your washing machine this may be used. Maximum temperature 30 degrees, using a mild detergent and if possible do an extra spin following washing to make sure most water is out of the fabric. Then to dry don't put it in a tumble drier as this can cause mis-shaping, instead leave to dry naturally (not in direct sunlight as this can cause discolouration) and make sure fabric is fully dry before putting back onto unit for use as damp areas can cause mould or mildew growth.
I have a Duet front loader and I've noticed that my towels get stiffer the more I wash them. I used to use liquid detergent and fabric softner, but the repair man suggested I use powder soap and...
No truth to powder being better .fabric softeners on the towels is fine it does help keep them soft they just don't absorb moisture as well.. I belive you biggest issue is over drying the towels,use a lower temp setting on dryer and do Not trust auto dry settings for towels,expermint with timed settings, if towels are not dry you can always add a few more minutes,but over temp and over dry will stiffen and age them prematurely
Bleach & Fabric softner tray not working.
Remove the drawer by pushing the tab at the top of the drawer and pull it out and check for an obstruction. They regualarly plug up with gummy fabric softenener. Try washing out with hot water and reinstall
Wrinkles!!!!!!!!
This is a frequent complaint with the following known  solutions:
  • You might be drying them too long. back the time down so that the cool down cycle happens right as the clothes are dried.
  • Try smaller loads.
  • You should dry heavy fabrics and light fabrics separately.
  • Fabric softener in the washer may help to prevent wrinkles from forming in the dryer.
3answers
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Top Washing Machines Experts
john h
