Andrew is correct
you should be on the way to a hospital in an ambulance
unless you are one of thousands that have got a home blood pressure testing machine and do not know how to calibrate it or it is faulty in which case junk it and keep going for regular tests at the doctors , pharmacists or chemists
- High blood pressure is generally a chronic condition and is often associated with few or no symptoms.
- When symptoms do occur, it is usually when blood pressure spikes suddenly and extremely enough to be considered a medical emergency.
- Rare symptoms include dizzy spells, headaches, and nosebleeds.
High blood pressure is often associated with few or no symptoms. Many people have it for years without knowing it. However, just because high blood pressure is often symptomless doesn't mean it is harmless. In fact, uncontrolled high blood pressure, or hypertension, causes damage to your arteries. High blood pressure is also a risk factor for stroke, heart attack, and other cardiovascular problems.
Their are two (2) lines coming out of the back side of the pump, one of them will have a hose type clamp on it and be a bit big around than the other, that one is NOT the high pressure line. it is the return line.
DTC P0532: Air Conditioning A/C Refrigerant Pressure Sensor Circuit Low Voltage.
The engine control module (ECM) monitors the high side refrigerant pressure through the A/C refrigerant pressure sensor. The ECM supplies a 5-volt reference and a low reference to the sensor. Changes in the A/C refrigerant pressure cause the sensor signal to the ECM to vary. When the pressure is high, the signal voltage is high. When the pressure is low, the signal voltage is low. When pressure is high, the ECM commands the cooling fans on. When pressure is too high or too low, the ECM will not allow the A/C compressor clutch to engage. P0532 Chevrolet Refrigerant Pressure Sensor Circuit Low Input
Hello, what is your high side pressure? A bad compressor will show abnormally high low side pressure with abnormally low high side pressure. That 45 low side pressure is low And superheat high. If you high side pressure is normal toma little above normal but the low side remains low you have a restriction in the system, that might be why it's not taking in tne freon. Let me know you high side pressure
I just saw the part about where you have high pressure. Are you using the regulator to regulate not only tank pressure but pressure going to tool? If the tank regulated pressure isn't working, that would account for both high pressure AND high temp. You can buy regulators relatively inexpensive. And don't for get to drain the condensation everytime you use it, or daily if it is a work tool.
Try dropping the tank pressure down to 150 PSI if you haven't done so. Tap the glass on the guage several times to make sure the needle isn't stuck.
