The display can be viewed only halfway opened and must be held close to the face. A common problem with Hisense...so I've heard. A receipt for purchase is only used for a product replacement within 2 weeks. After that it's a To bad, so sad reply. My 7 year old doesn't know this and continues to use this Hisense laptop. I can repair but don't know a proper instruction. Thanks, in advance.
SOURCE: Help to repair ACER Travelmate 290LCi
this is normally motherboard or powe side problem check your motherboard
SOURCE: Blank Laptop Screen
sorry about posting for trouble.
similar blank screen problem with Toshiba satlite notebook but I can see the desktop with no light from lcd. so if you just see the screen it's black untill you see very close to the monitor. When it boots i can see the normal screen and it goes away blank. Any suggestion?
SOURCE: Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
SOURCE: D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
SOURCE: ONLY THE TOP HALF OF THE SCREEN WORKS BOTTOM 2/3 FUZZY
the drivers are corupted, did it come with anytype of software, you mite have relaod the video drivers for that machine, but i would try getting any updated software.
go into control panel open up device manager, open display adapter or right click the on while on display adapter and select updated software.
www.drivershq.com
www.hp.com/drivers
hp has a very good customer service line that maybe abile to help you faster than 4 wks.
rodgandysr
