Canon Pixma MX410 All-In-One Printer Logo
J
Jeff Moy Posted on Feb 24, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Duplex printing not working, even when printing preference is set to "duplex printing" and under page setup, please help. Thank you
PC windows 10. Had made sure printing preference and page setup are set to "duplex printing", yet always print in continuous pages. What did I do wrong ? Thanks for the help!
Dennis Maeder
Level 2:
Sergeant:
  • Expert 257 Answers
  • Posted on Mar 20, 2016
Dennis Maeder
Expert
Level 2:
Sergeant:
Answers
257
Questions
0
Helped
130368
Points
647
There are detailed instructions in the user manual at P007
You can download your manual here: http://www.canon.co.uk/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_mx_series/pixma_mx410.aspx?type=manuals&language=
5 Related Answers
Anonymous
  • 320 Answers
  • Posted on Sep 17, 2008
SOURCE: Page setup for printing
In the file document you will find the tab called FILE. Click on it, and go to page setup. There you can change the edit the border or select the type of printing to A5, A3 etc.. And you can even also select landscape or portable. Thank you.....
Anonymous
  • Posted on Nov 29, 2008
SOURCE: MP610 How do I duplex
I had the same problem, the operative being had!
All I did was change the paper orientation from landscape to portrait and the problem went away!
Hope this helps!
Robbie
Anonymous
  • 60 Answers
  • Posted on Apr 06, 2009
SOURCE: Duplex printing flips page
That should be a setting somewhere in the printer or the print driver on the computer.
Here's a link to the manuals that comes with it.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=16279#DownloadDetailAct
Anonymous
  • 1738 Answers
  • Posted on Dec 01, 2009
SOURCE: Trying to duplex print a word document as booklet.
I am MS Offfice Systems as part of my degree. I have two courses in word. What you need to do is to click on the office button, click on print, and click print again. Click on the properties button on the top right on print dialog box. In the selection box about fourth option down where it say Two-sided (Duplex) Printer click on that. That should do it for you.
Ron Johnson
  • 127 Answers
  • Posted on Mar 31, 2010
SOURCE: Mottled effect on one face during duplex printing
that would b the fuser if it has build up on the rollers.. definitely change out the magenta toner and verify that the paper stock is within specs!
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
I am trying to set the printer to automatic duplexing...?
Hi
If you want to set Print on Both Sides (duplex) as the default setting for all print jobs (even single page jobs) use the following steps.
  1. Click Start , Printers or Printers and Faxes from the Microsoft Windows desktop.
  2. Right-click the HP Color LaserJet 2605dn_2605dtn and select Printing Preferences (Properties in Microsoft Windows 2000).
  3. Click the Finishing tab.
  4. Select Print on Both Sides under the Document Options section.
  5. Click OK to save the setting and close the Printing Preferences window.
  6. Close the Printers or Printers and Faxes folder.
Note:In this scenario, all print jobs, even single print jobs, will be treated as Print on Both Sizes (automatic duplexing) for media that is supported by the duplexing unit. For media that is not supported by the duplexing unit, the job will be treated as Print on Both Sides (Manually) (manual duplex).
2answers
How may i print for Both Side Printing?
Both side printing depends on the printer. It's a feature which require a hardware in the printer known as Duplexer. Which automatically turns the paper and prints on the other side. Some printer may not come with duplexer but if they support duplex printing, you can but the duplexer for the specific printer and attach it at the back of the printer.
If your printer supports duplex printing, when you click on print, click print preferences as shown in the fig 1 below.
Fig1
Click on finishing tab >> put a check on Print on both sides under document optoins section
Click Ok to close the preferences window
Click Ok to send the print job to the printer
Below is the series of images showing how to connect a duplexer.
FIG1
FIG2 - Press the buttons to take out the back cover
FIG3 - Connect the duplexer in the same place
Regards,
Shrey
6helpful
2answers
MY Ricoh Aficio 2550 Printer I use it via IP in windows 7 and can't print Duplex Unit it said. Duplex :(Something conflict I can't Remember) Duplex: Unit not install
In Windows 7, you can right click on the printer under Devices and Printers, then select "Printer properties" (not "Properties"), then under "Device Settings" you can set the "Duplex Unit" to "Installed". Afterwards, you can go back to "Printing Preferences"->"Finishing"->"Print on Both Sides"->Print on Long/Short Edge.
How can i print both sides of paper on my magiccolor5550
IF you have the optional duplex unit installed on your printer then when you go to print something, your printer setup screen should have a duplex/2 sided printing box you can check. This will be under printing preferences or properties. If you do NOT have the optional duplex option then you have to manually duplex. That means on say a 2 page document that you want 10 copies of you have to print 10 copies of page 1. Then take those 10 copies and place them back into the paper tray and print 10 copies of page 2 onto the backs of page 1.
Those are you 2 choices for duplex printing.
Good Luck and Thank You for using Fixya.
3helpful
3answers
My book fold booklet is printing upside down when duplexed!
You may need to tell word you want your printer to flip on the short side and not the long side. With my Canon printer I get a drop down menu IN WORD (not printer setup) that gives choice of: print one side; print two side flip on long; and print two sides flip on short.
Duplex still has problems printing double sided.
Hi, Please find the work around steps to resolve duplex printing issue in Windows Vista. Please the send the *.gpd files to the cu via mail before doing the steps. Duplexer Printing for Windows Vista Troubleshooting steps 1.start-all programs- accessories ? cmd -right click-run as administrator 2.Stop the Spooler service - Type net stop spooler 3.Change current directory Type cd windows\system32\spool\drivers\w32x86\3 4.Backup the old gpd files - Type copy hp*.gpd *.bak 5.sent the zipped file to customers email address through astro and then download the file to customers desktop 6.extracted the files from the zipped folder and then pasted those files to windows\system32\spool\drivers\w32x86\3 7.Remove old BUD file Type - del HP*.bud file 8.Restart to spooler service - Type net start spooler 9.checked under printing preferences if the both sided printing is selected as automatic and then tried printing a two page document 10.checked whether its printing or not. 11.) Start-Control Panel- Printer & Faxes- Right Click On the printer -Properties-Device settings-Disable the manual Duplex printing-Click on Installed Two sided printing-click on apply & ok. 12) Then Go to Right Click on the Printer-Printing preferences-Paper quality-Select Two Sided Printing from the top drop down list where its showing What do you want to do? 13) From Print on both sides-Select Automatically from the drop down list. 14) Try to print on both side check whether its working or not.
3helpful
2answers
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Canon mx850, paper jams when reloading for two sided copies. once the 1st side is printed the paper is released, recaptured and starts to feed back into the prt. 1/3 into the feed it jams, paper is...
Mel, this is what I found in the online manual:
Set the Ink Drying Wait Time longer.
Doing so gives the time enough to dry the printed surface so that paper curling and ink blots are prevented.
(1) Make sure that the machine is turned on.
(2) Open the printer properties dialog box.
See Opening the Printer Properties Dialog Box Directly from the Control Panel.
(3) Click the Maintenance tab and then Custom Settings.
(4) Drag the Ink Drying Wait Time slide bar to set the wait time, and then click Send.
(5) Confirm the message and click OK.
Make sure that the actual size of the paper is suitable for automatic duplex printing.
The sizes of media suitable for automatic duplex printing are A4, Letter, A5, B5, and 5" x 7".
Load paper of suitable size and then press the OK button.
Make sure that the Page Size or Paper size setting matches the actual size of the paper with a size suitable for automatic duplex printing.
First, check the Page Size or Paper size setting in the application software you are printing from.
Then, check the Page Size setting on the Page Setup sheet in the printer properties dialog box (Windows) or the Paper size setting on the Page Setup dialog box (Macintosh).
Note
Depending on the version of the application program, the automatic duplex printing may not be supported.
Make sure that the type of loaded paper is suitable for automatic duplex printing on the Main sheet (Windows) or the Quality & Media sheet on the Print dialog box (Macintosh).
Note
To switch to manual duplex printing, follow the procedure below.
Open the printer properties dialog box, clear the Automatic check box on the Page Setup sheet, and reprint.
When performing manual duplex printing, note the following.
If you are printing three or more pages of a document with manual duplex printing, one side of all sheets of paper will be printed first. Turn over the paper and reload the paper in the machine, and then the reverse side of all sheets of paper will be printed. Be careful not to change the order of paper in the stack.
The procedure for reversing the paper varies depending on the staple side and printing orientation. Follow the on-screen instructions.
MX850 series On-screen Manual for Windows:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16279
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
8helpful
Duplex printing in HP 2420dn
I had the same problem. It was due to incorrect properties in the printer settings.
  1. Go to Start >> Printers and Faxes
  2. Right-click on the HP 2420 printer and select Properties.
  3. Go to the Device Settings tab.
  4. Under Installable Options, set Duplex Unit to Installed.
Also, make sure that the Printing Preferences are set to Two Sided Printing:
  2. Right-click on the HP 2420 printer and select Printing Preferences.
  3. Go to the Printing Shortcuts tab.
  4. Select the Two Sided (Duplex) Printing option.
That should do the trick.
HP - please change your setup so that this is set by default!!
Brian Z
old marine
old marine
ZJ Limited
ZJ Limited
