I will need more information on make and model of embroidery machine this is.... a system reset need to flush out the memory and delete improperly saved or partially loaded embroidery designs.
Also found the following comment to a review: Jo-Ann16 May 2013 at 07:30
"Hello, I have the ambition 1.5, absolutely love it. To switch the font to normal stitching you have to delete or save the sequence. To delete it just tap the little garbage photo and to save tap the heart. With that done you then go back to your stitching tab select a stitch and tap the little garbage bin to erase sequencing and go back to normal stitching."
If you have the machine connected to the computer you can delete the embroidery from your machine, Artlink software is for this machine to write designs or read designs from your machine.
Check the tension. Bobbin tension. You need to use only Isacord thread. The cheap stuff will get caught and break the needle everytime.
YES you can delete designs. When the screen is up that is showing you what it is stitching. Click on grey box that pulls up everything you have ever stitched and click on one and then select delete.
Unfortunately, they are not recoverable. Next time you need to change the batteries, make sure the machine is plugged in to ensure that what is in the user memory is retained.
Unfortunately you will have to re-enter your patterns.
Happy stitching, Kim & Linnette www.sewingexpressions.com
Your internal memory files could be full and need some designs deleted, the monogram design might not be centred in the hoop so it registers outside the sewing field, The hoop selected might be too small for the design.
